Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Will not dispense water or ice
Ice maker is working fine--just will not dispense ice nor water from door
  • corie1 Aug 29, 2008
    We have a side by side kithcen aid and it is making ice, but the ice dispensor and water does not work??? can you help?
Check for broken or frayed wires at the bottom of the freezer door.
There is a wire harness that is routed around the bottom of the freezer door right by the hinge.
After many opening/closings of the freezer door, these wires tend to break or fray and short or open.
Posted on Jan 03, 2009
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Mar 19, 2011 | Refrigerators
Ice maker has stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689sshg
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
heatman101
sfhgsyw54
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
115 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
