Kenmore washer will do everyything but final rinse
My Kenmore washer will do everything but the final spin. The water empties from the tub. After the timer finishes I can set the dial to spin & sometimes it spins & sometimes it doesn't. When it doesn't, all I have to do is open & close the lid & it will spin. Is it the the lid switch?
My Kenmore washer does not spin on the final rinse. If it spins on the wash cycle but not on the rinse cycle then how can this be the switch at the lid? When the timer reaches the spin part at rinse all I have to do is push the timer to off and pull it back to on and it spins just fine. Is this not then a bad timer? Also this problem is at only rinse but on both wash cycles on the timer.
I have run the machine with the lid open with a dowell inserted into the switch to defeat it. I watched the cycles and when it got to rinse spin it did not spin. Even by depressing the lid switch a few times it did not spin until I reset the timer by going off and then on.
Do you still say that this is a lid switch problem?
also the model number is a 11020712990. The lid switch is on the right.
  • 5,911 Answers
Sounds like a lid switch to me. The symptoms you describe are often caused by a lid switch malfunction. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949238). The lid strike is listed as item 20 (part #350733). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually costs between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: Future reference (this is just constructive advice), if you are in the habit of slamming the washer lid or placing heavy objects on the it, this will cause damage to the lid switch. In addition, also make sure your washer lid is not bowed. Placing objects on the lid can cause the lid to bow and prevent it from making the proper contact with the lid switch. This will give you the same symptoms.
Posted on Aug 22, 2008
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
This is a very typical symptom of a lid switch that is either broken or has come loose. If your lid switch is mounted on the right hand side of the lid, make sure the mounting screws are tight and the lid strike is in place (this is a plastic piece on the lid that activates the switch when closed). If your lid switch is on the left hand side in the rear under the washer rim (out of view), you may have to adjust the rod that activates it. For instructions on how to access the lid switch and/or replace it, click on the following link:
If you need further assistance, please post back and let me know. You can also go to my profile and use the "Ask Me" feature for a quicker response.
May 27, 2008 | Kenmore 22422 Top Load Washer
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
222 people viewed this question
Top Washing Machines Experts
