Question about NAD C320 2-Channel Amplifier
Peavy amp 2000 will not power up or reset - NAD C320 2-Channel Amplifier
  • 682 Answers
Disconnect all input and all output and check if the problem solved you will have an problem in surrounded world-start with one input and one output speaker and check if it is ok go to next speaker until you find the bad one-----if all above failed your amp needs to be inspected in service center.
Posted on Aug 24, 2008
Phonic mm1002
You need a 3.5mm stereo jack to twin 1/4" jack plugs. That will get audio from your laptop to the mixer. Then, being Peavey, probably a pair or jack to jack 1/4" screened leads for signal from mixer to amp. Then loudspeaker leads to suit your amp and speakers.
Jan 02, 2014 | Computers & Internet
How to fix extra speakers to peavy xr 886 and get the same power to each sperkers not just daisy chain each extra speakers
This powered mixer can only drive 4 ohms a channel...two eight ohm speaker cabinets daisy-chained makes one four ohm load. Ampifier wattage output ratings are usually higher driving four ohms than eight BUT never drive a lower rating than advertised by the manufacturer.
If you need more power than the mixer can provide, connect the "Master Out" or "Mono Out" connections (next to the speaker output jacks) to an external power amp. Connect additional speakers to this external amp and you're done.
Nov 12, 2013 | Audio Players & Recorders
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
The SP5G Peavey Speakers are a good combination for the MP5 Plus?
Those speakers are capable of much more power than that little powered mixer can deliver - my 5G's are rated for 800 Watts program. I use a pv2600 to drive mine - at 8 ohms per side that's a good match. Depending on what your using the setup for...my concern would be that a small amp like that could get turned up high enough that you'll be clipping - thereby sending nasty squared waves at the speakers - they won't like that much. If you want much volume - you should look at a bigger amp. If you're going very low key...those speakers are overkill.
Jun 08, 2012 | Music
What fuse does a Peavy Mace take
depend of the power I= P/E 15-20AMP FOR 22O VAC
God bless you
May 17, 2012 | Music
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
My Peavy 2000 Escort does not turn on . I checked power caple,power etc and nothing .. it is a good product and would like to fix it , any help?
We here at Pro Line Music are Peavey dealers, and service. If you can get the unit to us we could fix it.
215-736-8055
Jan 02, 2010 | Peavey Escort 2000 Microphone
Plug in Numark mixer & twin CD player to a Peavy CS 1200 x amp. There are diagrams but im lost
simple.numarks outs to peavey's inputs.probably rca's to quarter or rca's to xlr's
Dec 08, 2007 | Audio Players & Recorders
NAD C320 2-Channel Amplifier Logo
56 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
