How can I save a picture on my TZ10 lumix after I have zoomed in to enlarge the frame ? i.e. I want to save the enlarged version to download onto my computer
To enlarge the print when copying on the HP Envy 4500, you can adjust the zoom or scaling settings in the printer software. Here are the steps to follow:
1. Load the document or photo that you want to copy onto the scanner bed.
2. On the printer control panel, press the Copy button.
3. Use the arrow buttons to navigate to the Zoom or Scaling option and press OK.
4. Use the arrow buttons to select the percentage by which you want to enlarge the print. You may be able to choose from a list of preset options (such as 125%, 150%, or 200%), or you may be able to enter a custom percentage.
5. Press OK to apply the changes and start the copy job.
If you're using the printer software on your computer to control the copy job, you may need to follow slightly different steps depending on your operating system and the version of the software you're using. However, the basic process should be similar. Look for options related to zoom, scaling, or print size, and adjust the settings as needed to achieve the desired level of enlargement.
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio
as the original, and also interpolating the result back up to the pixel
dimensions of the original. this method involves cropping, hence the
resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subjectwithout moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards, Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
The pictures probably cannot be enlarged any further. Try saving the picture and then viewing it from your computer. You may be able to zoom in and a better look at the picture
There are few methods to enlarge the pictures. You may open MS-Word - insert the picture (insert - picture) - now select the picture in MS-Word and extend the picture with the mouse. Now save as the word file in HTML format and check the saved folder - you will get the enlarge picture file there in the folder.
Another way to enlarge is Photoshop. Open Photoshop - import the picture - select the picture and enlarge it - then save as usual.
Are you using the optical zoom or the digital zoom? digital zoom only enlarges the pixels and eventually distorts the picture. Optical zoom actually brings the subject closer.
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
I don't think that's a feature of the product. I believe the zoom and panning is a convenience for the immediate viewing of the picture but can't be preserved.
Frame width is normal means. Check aspect ratio is changed in menu options. Even width is also enlargement means there is high output from power supply section. Check and change the high voltage filter capacitor.
