Question about SanDisk Sansa m240 MP3 Player
Headphone connection the headphone jack connection is reliable. I have got to wiggle the plug to get a good connection.
  • 8,596 Answers
Common to all mp3 players - there are a few videos on YouTube purporting to show you how to fix the headphone jacks, but they usually don't work. Replace the mp3 player is the only solution.
Posted on Dec 10, 2008
SOURCE:
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
I have a 2002 Chrysler Town & country and I can't get the sound to work for the Vcr/player Without headphones. How do I get the sound without the headphones?
I had one of these and it turned out to be the headphone jack, when you put the headphone plug into the jack it disables the speaker and when you unplug the headphones it enables the speaker. There's a contact in the jack and it is probably stuck to headphones. The jack may need to be replaced. Try and wiggle the plug a few times but not hard as it may break from the curcuit board.
Oct 19, 2014 | Cars & Trucks
Why i have to wiggle the headphone jack to get sound
Two possibilities:
1) either the earbud plug has a loose connection, or
2) a soldier joint in the player itself is cracked.
Have you tried different earbuds? If that fixes the problem, then yea!
If new earbuds don't fix the problem, the it's likely a cracked soldier joint. Cracked joints are easy to repair, IF you have the right soldiering iron and are a careful working who enjoys learning new skills.
Good luck.
Sep 25, 2014 | SanDisk Sansa Clip MP3 Player
My Laptop Headphone Jack on my acer 7551 - I have to wiggle the headphone wire end to get a sound, then hold [email protected] angle, very sensitively in place, or else the sound will go again - i think the inner...
Your inner jack could be jacked jack LOL . No really sometimes the inner connection gets loose or the connection to the headphone jack port not making good contact might need replaced if you know that your head phones themself work fine!
Jan 21, 2013 | Acer Aspire Computers & Internet
My Skullcandy Hesh headphones have messed up sound with my ipod
I would say that if they work fine with other devices then your input jack on your ipod is bad. First I would plug other headphones into your Ipod and see if the problem persists. If not the case then I would plug in your headphones into a known working device and wiggle the wire at the connection point to see if you can duplicate the problem. If this does happen then you need to replace the connector (1/8th inch stereo male plug) on your headphones.
Oct 22, 2012 | Skullcandy Hesh Overear Headphone...
HDR 120 PHONES. Sound on right phone has dissapeared but right phone is ok. Batteries have been checked and are fully charged. Any suggestions. I have checked all the connections and all look solid on both...
Hi, What test did you preform to know the right phone is OK? Connections can look solid to the naked eye but not be the case. What are you using to test these phones? Make sure the the plug you are plugging your jack into is functioning properly so you know you will get a proper test of the phones themselves. With the phones on your ears and plugged in and music playing can you wiggle any of the wires or connections and hear any crackling? This will give you a good starting point to address. Good luck.
Mar 06, 2011 | Sennheiser HDR 120 Consumer Headphones
My left earpiece in my sentry headphones have no sound. How do I fix this?
Check the plug - it might have a broken wire, by wiggling it in the jack. It could be the jack as well - try another headphone in the jack.
Nov 08, 2010 | Sentry HO900 Headphones
How do I fix a bad connection with the headphone jack on my ipod touch? When plugged in, the music is static-y. It is definitely the headphone jack that is the problem.
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Jul 23, 2009 | Apple iPod touch
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Aspire 3680-2574 Headphone jack
did you try another set of head phones? the jack for the headphone where it was soldered most likely broke off you can take apart and try and resolder it.
Jan 04, 2008 | Gateway M305CRV Notebook
SanDisk Sansa m240 MP3 Player Logo
99 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
