Question about Xerox Office Equipment & Supplies
H4 code on XC1255 - Xerox Office Equipment & Supplies
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Aug 22, 2008
ERROR CODE h4-00
H4-0 = The fusing unit doesn't heat up.
http://www.visualhawk.vcc.ro/sharp_error_codes_en.html
Mar 06, 2015 | Sharp MX-B201D Copier
Need to clear a code H4-001
I am a tech that services Sharps.
Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Mar 06, 2014 | Sharp FO-2081 Copier
1 have a xerox copier model XD120F Had apower outage when copier cam back on screen is showing a H4 and not powering up thanks Joe
Hello
Since the problem occured after a power outage,you should try resetting the H code.
Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code should vanish and your copier should work well.
Apr 17, 2011 | Office Equipment & Supplies
SHARP AR-M155 system error[H4-00]
Apr 13, 2011 | Office Equipment & Supplies
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Jun 03, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Fuser lamp on xerox model XC1255 needs replaced
Are you asking directions or where to order.
Anyhow, Either way, google "the parts drop".
Call and ask for Britt, he will have the part at a fair price and
most likely can send you directions.
I don't work there, just have done business with them for years.
First class business.
Aug 11, 2008 | Xerox Office Equipment & Supplies
447 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
