Question about Teac Audio Players & Recorders
Plays CD 107 minutes and goes back to start
When clicking play button, the player plays about 107 minutes and goes back to start and will not play forward tracks, window view show NO. The Disc seems to be turning and can hear some sound in track 2 momentarily, then the window shows NO and then shuts down.
  • 1 more comment
  • brickeytree Aug 22, 2008
    I did not see a solution to my Problem with the TEAC PD-X100 in your posting. As I mentioned when you press play the CD plays about 107 min. then reverts to start of the track again, over & over. If you choose track 2 it will not change or play and a NO comes up on the window.
  • brickeytree Aug 23, 2008
    Did the CD Cleaner and it did not solve the problem. Do you have other suggestions?
  • brickeytree Aug 26, 2008
    I tried the CD Cleaner with the same results. stops playing at 107 minutes and reverts to starting position over and over, also will not play advance tracks, noting a NO appears in the window.
  • 2,337 Answers
There seems to be a mechanical/electrical problem with the lens transport mechanism. This repair might not be DIY and the parts might not even be available.
Click here to see the part you need to fix your device. Some vendors might just sell the lens transport mechanism without the lens.
I would suggest to contact the manufacturer if your device is less then a year old.
Let me know if you need further assistance.
Posted on Aug 26, 2008
    Genius:
  • 1,447 Answers
Hi-
Two things: it may be the CD player or the Disc itself. But if it doesn't happen to other cd then chances are its the disc.
Hope this helps
  • 928 Answers
Most often problems such as this are caused by bad media, meaning the problem is with the CD especially if the CD was not written correctly. Try to use a differnet CD and see if the same problem occurs.
Posted on Aug 23, 2008
  • Anonymous Aug 26, 2008
    Have you already tried to use a different CD?
    Master:
  • 623 Answers
U must have dirty rails clean it it is where the lens rest
  • 435 Answers
If it happens with all the CD you play, then it has to be lens. Try to clean it with some spray cleaner.
Let me know if this helps.
Thanks
Posted on Aug 22, 2008
    President:
  • 1,450 Answers
Plays 107 minutes or 1minute7 seconds of first track?
  • 6,487 Answers
This can be a lens problem, the players lens having a hard time reading the disc probably its bad or just dirty, try to run a CD cleaner to make sure the lens is clean...
Good luck.........
  • Mark Gil
    Mark Gil Aug 23, 2008
    If you know how to open the player and clen the lens with a cloth , you can try that. But let me tell you there's a possibility that you may need to replace the lens of it..
  • 1,879 Answers
Happens to other cd's ?
SOURCE:
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
Random song shut down
if its a nsm then go into programme mode then p100 then 0 + h this disables all backgtound music
Apr 03, 2014 | Wurlitzer Jukebox CD Player
Panel lights up, plays CD, plays iPod, but none of the controls work.
switch off, remove battery and replace it after two minutes. switch on. Goodluck Mark
Dec 03, 2013 | JVC KD-HDR50 Car CD/ MP3 Player
I just purchased a Rowe AMI CD-100a. It was a barn find. Once I learned to initialize, I tried to play individual tacks or entire CDs. For each track, the unit picks the CD, places it down on the player...
Could be the power supply voltage is low, possibly due to a bad capacitor, it seems that when the counter advances it is pulling the voltage down enough to cause the problem you are experiencing. If you can select a disc in the service mode, the counter should be inactive, and you can see if the disc will play through.
Sep 29, 2013 | Wurlitzer Jukebox CD Player
IVA-D310 PLAYS DVD'S BUT NOT CD'S!
As last resort you might try a firmware upgrade if available. Otherwise the unit needs to be replaced since laser mechanism has lost the ability to focus on and play back cd's. Repair not cost effective so ..............
Aug 26, 2017 | Alpine IVA-D310 Car DVD Player
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
Cd player dosen't play with amp
hmmm...what cd player are you using?..
May 03, 2008 | Kenwood KDC-MP828 CD Player
Pioneer elite pd-f27 300+1 cd changer
I've owned two of these players, one currently, and both exhibit this behavior. Although frustrating, it seems to be inherent in the vertical loading mechanism. Every finicky CD I pull out of the PD-F27 plays perfectly in my single-loading tray player, including CD-Rs. One would expect more of an "Elite" product, but there you are.
Mar 17, 2008 | Audio Players & Recorders
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
87 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
