Question about SanDisk Sansa e250 MP3 Player
I need a logiciel to for my mp4
Firstly i i can't install my mp4 digital player on my pc
2nd my mp4 have problem of opening....
thanks ,so much
  • 8,596 Answers
Call the manufacturer.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Sep 08, 2008
SOURCE:
How do i transfer video from laptop to mp4
Hi there.
To transfer the video from your laptop to your mp4, make sure that the video is a file that can be read by your mp4 player. In that case, it should be already an mp4 format.
Check if you need any software to be installed in your laptop for it to recognize the player when connected. Usually, a software installer is included in the package. Just download it.
Once installed, connect your player using the supplied cable to the laptop and start the transfer.
Hope this helps.
Let me know if you need any questions.
Thank you!
Sep 27, 2011 | Philips GOGEAR SA6045 MP3 Player
Can I watch MP4 movies directly from my WD My Passport Essential drive without having to save on computer hard drive first?
YES
All you need is an mp4 program on your computer.Here are some links 4 some free ones
http://en.softonic.com/s/mp4-player
After installing a player of your choice. jus go into the hard drive 1)right click on the file
2) open with
3)choose the player you want to watch the movie on
4) press enter.
Jul 27, 2010 | Western Digital WD Passport 250GB Portable...
LaserMP4-Q12 Personal Media player. Cannot get music files to pl
ya u have many option to solve this problem. first is that ur music format not supported ur player so it show this message. 2nd u can download ur driver from internet. 4 this u can try in google just type this what do u want. then u will get. 3rd is there are many software for convert mp4. 4 example u can use total video converter, im too mp4 converter. thanks
Aug 08, 2009 | Laser MP4-V970 MP3 Player
Download songs
connect your mp4 player to your pc/notebook with the help of the usb cable provided with the same....copy songs from your pc/notebook and paste them into the mp4 player which will open as a memory device...
May 15, 2009 | Element Electronics Zr-Element Digital...
MP3/Mp4
Dear All
My ACTIONS HS MP4 USB Flash Disk has a lean screen. i switched on for the first time and the top edge slant from left to right. checked the Menu Options but no luck. i know you can scare up a normal monitor screen but dont know how to sort this one out.
thanks for any help
bret
Feb 24, 2009 | Lasonic MP3 Player
How to insert songs/movies in 80GB apple ipod classic
Just few steps:
  1. download iTunes from www.apple.com
  2. install it on your PC
  3. Open iTunes
  4. connect your iPod to your PC
  5. iTunes will detect your iPod
  6. then you can synchronise your songs easily, you can drag & drop songs to iTunes too
Please rate my solution.
Thanks..
Jan 03, 2009 | Apple iPod classic MP3 Player
Cannot install drivers and set up for my mp4 on my PC
Hi! Can you see an icon namely setup in amv transfer tool or AMV tool setup? If yes then double click it and it will install the software needed to run your player. And after the software and drivers get installed connect your player to your pc.
Dec 31, 2008 | Audio Players & Recorders
China MP4 player Hangs when switched On
change the firmware is best way to tackle this problem
open your mp4 and read every no.- digits carefully and then download firmware........... be carefull firmware should be same as your mp4
Nov 08, 2008 | Audiovox MP4128 MP3 Player
Can't play videos
You need to use the Media Converter that came with the installation CD - must run video files only through it. Check manufacturer's website for software if you no longer have install CD.
Jun 25, 2008 | Audio Players & Recorders
MP4 player instructions
To add music
plug mp4 into usp, open ''my computer'' then copy and paste your music into mp4 drive, most likly drive E
to add video
install the mp4 software, then use the conversion tool to convert your video files to amv format then just copy and paste into mp4 drive just as you would with your music files.
Dec 26, 2007 | H&B MP401 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
