Question about AMD Athlon 64 X2 3800+, 2.0 GHz Retail Processor
Sound driver i have recently taken a second hand system which was lying just like that for a couple of months ..... so when i switched it on was asking for reboot ..therefore i reinstalled the system with windows xp version 2002 ... but now i cannot hear any sound .... pop up keeps coming up saying no audio hardware detected ..... so kindly help me out how can i get the drivers
Hi please help me i want the driver sound for hp pavilion dv 6510 ef for windows xp pro 32 bits thanks (dodo_bernard@hotmail.com) thanks again
Posted on Dec 07, 2008
    Master:
  • 441 Answers
Usually the sound card are built-in on the mobo(motherboard), try checking the model and brand of the mobo and download the sound/audio drivers of it.
You may want to check device manager and see if the computer detects that there is a audio controller on the system. then install the drivers.
Posted on Aug 22, 2008
Windstar window clicking
I would need to hear this.
Jan 05, 2018 | 2000 Ford Windstar
Blank screen during playback with gigawire webcam
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Jan 31, 2012 | Radio Shack VGA PC Camera Webcam
I have a Hoshizaki KM900MRH ice maker. It will run fine for a couple days then shut off and beep 3 times within 3 seconds. I am told by tech support that it could be a float switch. Where is the float...
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
My son moved the monitor from one pc tp another and it worked great for a few days. Today he turns it on and the screen is black and blinks every couple of seconds. I have restarted, unplugged and checked...
Guess to narrow it down, can he put the monitor on another computer to see if it still works? Also putting different monitor on the current computer might give you a few more ideas. At least then you will know have a better idea of where the problem lies. Hard to diagnose this stuff unless you are the one sitting in front of it.
Hope this starts you in some direction.
Dec 09, 2009 | Samsung SyncMaster 205BW LCD Monitor
Speakers had been working fine for about a month. But recently they have started crackling when I increase the volume above about 1/3 and cut out every couple of seconds if i increase the volume to 1/2.
uninstall and reinstall the sound driver and see if it works if that does not work try the same speakers to different sys. and check if it works the port of the sound card might have gone bad and if the same problem with other sys. speakers had gone bad.
Oct 27, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
Toughbook CF-51 Sound
You can download the XP drivers from the panasonic site. CF-51 got many flavors and be sure that your model numbers are at hand when you retrieve the factory installed drivers.
Delete all SigmaTel drivers from the registry hardware section. This would help reinstall the correct driver. The presence of these wrong registry values prevent successful installation of the factory drivers.
I have installed se7en, vista and XP successfully. The sound is really problematic since Dell and Gateway laptops use similar sound chips and offers drivers on the net... but they don't work at all. The Gateway driver seems to install perfectly from device manager report, but only the mic works & no sound.
What I do is install the factory provided drivers in XP compatible mode and then use windows update to download the latest SigmaTel drivers (se7en pre-beta). Windows got a more compatible driver but it can only install over the original since the chips cannot be recognized.
Jun 12, 2008 | Panasonic Toughbook CF-51 Notebook
High-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
Mar 02, 2008 | Sony DAV-FC7 System
TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Dec 28, 2007 | Teac CD-X9 Shelf System
My system does not startup ....
try deleting and reinstalling the drivers on it they might be corrupted or something
Dec 21, 2007 | Intel Motherboard
AMD Athlon 64 X2 3800+, 2.0 GHz Retail Processor Logo
295 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
