I have 2 a/c units. The upstairs unit tries to start and after a couple of seconds it turns off. I went outside and the blades do not turn and it shuts off. Sorry for such a bad description Hd
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
"Stop right there"! Call a- repairman! Sorry for such a straight , (SHOOTING-FROM THE HIP) ANSWER but you'll thank me later-on! thank-you-very-much
Posted on Aug 23, 2008
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Ac compressor will not start
Hello, sounds like a faulty capacitor. Check the capacitor to see if it is puffed up at the terminals. It will be located inside the outside unit and looks like like a can that is oval or round.
Jun 17, 2012 | Goodman Heating & Cooling
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
The thermostat is a White-Rodgers 1F82-261. We have the very same thermostat on both the upstairs and downstairs systems. Both thermostats have all settings set exactly alike. The upstairs system has...
Steps that you need to do.
First is to reset the unit by pressing the reset button for two seconds right below the fan switch.
Second is to re- program the thermostat correctly, make sure that the unit work fine when the thermostat has been bypass.
Then monitor the thermostat operation, I think this will resolved the problem. If you need further assistance call this number 18002842925.
I have attached the link of the MANUAL
Jun 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Outside fan does not spin and a loud screeching sound coming from
Hey there, sounds like the bearings seized in your fan motor. You need to replace the fan motor. If the compressor runs without the fan, th pressures build up and if they reach an extreme point, the compressor will bypass internally, creating a loud sound as the high pressure is released to the low pressure side. I would turn the thermostat on and stand by the outdoor unit as it start. Leave the disconnect on the wall readily available so you can quickly turn it off. If the compressor sounds ok when it starts up and runs for a couple seconds, turn it off right away and replace the fan motor and you should be good to go. If the compressor sounds bad or real noisy immediately at start up, the fan motor not working killed your compreesor. You would need a motor and compressor, might as well replace the unit at this point if you are paying to have it done. Let me know if you need anything else
seth
Jul 03, 2009 | Carrier Heating & Cooling
Rick55 my outside unit goodman cjk484ab stopped working fan not turning motor very hot power went out for asecond then the unit stopped working i think the fan motor went out
check the capacitor if motor is real hot it might be burnt out winding can you get it to turn buy pushing the blades if so good chance it motor.
Jun 24, 2009 | Heating & Cooling
Hello, my amana heating and cooling will not turn. the outside(a-c unit) will turn on for a couple of minutes than shuts down. upstairs, the furnace will not turn. can you help?
Please give the model number, is the furnace gas or electric, and is the system a heat pump (which that can be determined by the model number.)?
Jan 28, 2009 | Heating & Cooling
Weather King Heat Pump
Hey kellyrepp -- Three things to check quickly, so many things can be wrong, but i will try to help with the info you gave me.
The first sounds like your electric aux heat is not wired in or not working correctly , this should kick in when the heat pump cannot keep up with desired set temperature. For sure thats a problem
The second thing i would check is that the compressor for that unit is running. It should sound exactly like the one for the upstairs, the fan noise should be like a whrrrr , and the compressor should be a semi loud hummm.
Third feel the pipes on the outside unit that are on the outside of the unit (the unit for the second floor) Let the unit run for 5 minuites. Now check that the first floor unit pipes are the same tempereture. They are about 110 degrees or so, depending on the outside temperatur , be carefull not to burn yourself. If the lower unit is colder , the two most prominent problems would be #1 the compressor is not running #2 Low on freon.
Hope that helps
Jan 13, 2009 | Weather King 12AJA4801AH Air Conditioner
FANS ARE WORKING BUT THE AIR IS NOT COLD
That was real deep diagnoses I'm betting the outside unit is the problem. check the outside for240-volts to the contactor if not backtrack for the lost voltages and remove the outside cover to check the little silver can (capacitor) for swollen at the top terminials, due to power surge.
Aug 19, 2008 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
