Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk Cruzer storage
I'm trying to backup MYDOCUMENTS folder to my SanDisk Cruzer 1 GB removable drive. It stops backing up files when it is only 57.3 MB full. There is still 918 MB free space but it will not back up any more files. The error is "cannot create file" or something like that.
  • 32 Answers
Check the format. Make sure it's compatable with the operating system. Also check the size of your documents folder. If they are compatable, maybe there is something wrong with the flash drive.
Posted on Aug 22, 2008
I have a .pst file that is 5 GB which I am trying to copy to a sandisk flash drive cruzer 8 GB. I keep on getting an error message stating the the file is to big for the destination file system. What...
Two possibilities:
1. you already have more than 3GB of files on the SANDISK.
So, delete some files, or "burn" them to a CD/DVD disk,
so that you have at least 5 GB of "free" space available.
2. the "file-system" (the way that the "table-of-contents" is laid-out on the SANDISK) limits the size of a single file to 2GB.
The "file-system" on your 'C:' drive does *NOT* have that identical limitation (it does have a "maximum-file-size", but it is MUCH larger).
Open Outlook, and "compress" all the folders.
Perhaps, the PST file will shrink to less than 4.7 GB.
If it does, then you can "burn" that file onto one DVD-writable disk.
Sep 25, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
What do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have an older HP Pavilion PC with Windows ME. I recently copied 164 Adobe Acrobat files from my ?C? Hard Drive to a 2 GB SanDisk USB 2.0 Flash Drive without any problems. Now I cannot copy any more files...
Sounds like the F.A.T. (File Allocation Table) is bad on the drive. Try to format it and then copy everything back to it once again.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 16, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can't remove U3 launchpad
I have had a similar problem to this one. It is relatively easy to fix. Step 1 - Backup any files that you want to keep from your SanDisk. Do this by going into my computer and clicking on the SanDisk removable hard drive. Drag and drop the files you want onto a folder on your computer. Remember - If you back up everything BE SURE YOU DO NOT BACKUP THE U3 LAUNCHPAD SOFTWARE. Step 2 - Get into your My Computer folder and right click on your SanDisk removable storage device and select format. After you format everything should be removed from the memory stick. Step 3 - Drag and drop the files you backed up back onto your memory stick. Done! Hope that helps.
Mar 16, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot move a Microsoft Word file to a SanDisk 2 GB Cruzer,getting the message that "Directory or File cannot be created"...Why? What's the solution?
There is a problem with these where putting files directly on the root folder of the drive only allows X amount of files. Open the Cruzer from My Computer and create a new folder. Try dropping the Word file into that new folder and all should be well.
Hope this helps. Look forward to hearing back from you soon!
Feb 26, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Who can fix my 1 gb cruzer? It has a bent port
Dog bites can be tough, they have beautiful teeth that can do some severe damage to a flash drive. I would be happy to get your data back for you. I run a simple mail in service here: http://happydatarecovery.com/
Dec 18, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a SanDisk Cruzer USB 8GB that is only allowing me 1.33 GB of space - says 6.594 GB used and there's nothing on here - how do I gain that storage space back? tx
There might be a hidden file(s) on the drive that are taking up that space. Open the drive in My Computer, click Tools > Folder Options... On the View tab, click Show hidden files and folders. Then check the drive to see if any hidden files or folders are present.
You can also try formatting the drive. Right click the drive in My Computer and click Format...
Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Launchpad problem
try getting them by clicking on start and going to my computer, your device should show up under removable storage.. double click and look in the folders for the device! there your files should be!
Search Engine Marketing and Optimisation - Increase Your Position
Dec 15, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
155 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
