Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Bosch sprayer arm found in bottom of dishwasher
The sprayer arm device was found in the bottom of my Bosch dishwasher. Are there instructions on how to repair?
Thank you
dmoss@sleh.com
    Sergeant:
  • 409 Answers
How many pieces is the sprayer arm and how many sprayer arms to do you have 2 or 3?
Posted on Sep 13, 2008
Top arm inside dishwasher fell off
You might need to reset or replace the spraying arm
Click on : Sprayer
Jan 23, 2013 | Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
The water is only filling the bottom of the dishwaher. It is not running through the sprayers
I'm having the same problem, was told to put in an anti sudzing liquid found near carpet cleaners at lowes... Haunt found it anywhere yet. Tried using dishwasher magic, but that didn't work either bc water never left bottom... Have u found a solution?
Mar 16, 2011 | Bosch SHE45M06UC Built-in Dishwasher
Spray arms blocked how do I detach clear/clean them?
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. In the center of the sprayer arm there is usually a wing nut that unscrews easily and releases the sprayer arm. Once you have removed the arms, rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | Bosch Dishwashers
My dishwasher used to clean very well, but is now leaving debris in my glasses and bowls. There is also a loose piece I found in the bottom of the dishwasher, not sure what it is for! The dishwasher is...
see if the sprayers are rotating(see where the arms are and start it, then open it to see if they have moved, the machine will stop when the door is opened)if not, remove the sprayer arms and clean them as best you can (make sure all the holes are clean) the arms can be removed by turning the x shaped thingy in the middle of it
Jan 10, 2010 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Spray arms do not turn. water to them but not
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Nov 30, 2008 | Dishwashers
Sprayer arm
the arm simply attaches to the underside of the basket. slide the front of the arm over the round bar on the underside of the basket then clip the arm over the round bar on the back of the basket
Dec 21, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Jun 15, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
185 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
