Question about HP LaserJet 2820 Printer
HP 2840 : Error 59:99 T2 Clutch error
Can I fix this problem? How
  • 3 more comments
  • yasodas Aug 28, 2008
    My error is almost same.
    It says - 59.99 error , Turn 0ff and On.
    Inspite of doing so, still it is not working.
  • astuckpoint Jan 23, 2009
    is error 59.99 remotely related to printer quality issues. My pages and intermittently printing very light ( hardly readable) after a few prints. My drum was low so I though it would fix the print quality issue but it didn't. I still have to replace my color cartridges. before i replace them I need to know why now with a new drum are pages printing of poor quality and if it is related to 59.99
  • Kenny Fixit Feb 23, 2009
    Howdy
    Same problem, LJ 2820 error 59.99..tried DC controller than the
    T-2 (cl-2)..No change...Any help would be welcome.
    Tks
  • angela755 Apr 09, 2009
    I have the same problem and changed both the clutches and still showing the same error. Any suggestions on what else it could be?
  • menbloody
    menbloody Dec 02, 2012
    it is the error of rotating cartrideges ghair and moter,can be resolve after service
  • 138 Answers
The problem you are having is with a clutch also known as CL2 or T2 Clutch. The part is available through HP at http//:partsurfer.hp.com. Just put in the part number RH7-5335-000CN and it will come right up for order. It cost 26.73 plus shipping.
The disassembly is a little intense but completely do-able with the service manual walking you through it. The clutch is part of the drive assembly on page 366 (#3). The diagram looks intimidating but its not as the full hunk can be taken off and then the clutch removed for replacement.
Here's a free copy of the manual:
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps you. If so hit it with a fixya!
Posted on Aug 30, 2008
Have you disassembled the drum unit? Because if you did so, then you didn't put on the right way two black rollers near the transfer belt.
Posted on May 03, 2010
It is much easier to replace the main gear drive assembly. The clutch is located on the assembly.
Posted on Mar 26, 2011
  • HP_ASP Mar 27, 2011
    Unfortunately tbe manual does not mention that when you pit the upper most gear in you have to position it to where it will lighn up with the top cover rail or the lid will not close properly.
LaserJet 2840 Error 59.99
Many drums have a chip with a lifecycle. You may need to replace the chip if you dont want to replace the drum.
Feb 05, 2014 | HP LaserJet Office Equipment & Supplies
Hp laser jet 2840 Error 59.99
T2 Clutch error: Check the cable
connections to the DC controller. If the error
persists, remove the imaging drum and
check the clutch. If the error persists,
replace the T2 clutch. If the error still
persists, replace the DC controller
May 26, 2012 | HP LaserJet 2840 Printer
Codigo de erro 59.99 na hp 2820
59.99-T2 Clutch error:
Check the cable connections to the DC controller. If the error persists, remove the imaging drum and
check the clutch. If the error persists, replace the T2 clutch. If the error still persists, replace the DC controller.
Jul 11, 2011 | HP LaserJet 2840 Printer
I have an HP 2840 and I have constantly been getting a scanner error 52 code. Per the text and research they say power it on and off, which did not work. Other experts say to replace the scanner...
hp 2840 error The device HAS Experienced 52 year internal hardware error. theoretically not initialize the scanner, to be replaced after that piece or set of diagnostic scan (logic board or motor, etc.
Apr 12, 2011 | HP LaserJet 2840 All-In-One Printer
I have replaced my imaging drum and now 59.99 eror turn of and back on will not go away any help fixing this problem would be great. Regards, Dale.
From the HP service manual
59.99-T2 Clutch error: Check the cable
(seeRemoving the DC controller
Any chance you got a bad drum unit? It could be binding which would cause this error.
Apr 04, 2011 | HP LaserJet 2840 All-In-One Printer
Hp color laserjet 2840 error 52.
I noticed that this was posted in Oct 2010. If you are still waiting for an answer,
the printer has a scanner error. Power off for about 30 seconds. Power on, if
error persists, the scanner assembly will have to be replaced.
I hope that you got it fixed by now!
Oct 04, 2010 | HP LaserJet 2840 All-In-One Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
HP 2840 "Engine Error"
engine error is the fact the the printer isnt turning, also may have a fault in one of the circuit boards.
Jan 05, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2820 Printer Logo
7,894 people viewed this question
Ben Johnson
