Question about IBM Infoprint 1422 Laser Printer
Printing duplicate copy
We have our 1422 on a network. The printer routinely as a 202 Paper Jam. The print document prints 3/4 of the way and then gets hung up. The user who sits by the printer presses the GO button...the document finishes printing and then an exact duplicate prints. I've turned Jam Recovery to *OFF but that didn't help. Any suggestions?
  • Anonymous Nov 07, 2008
    No idea yet what is causing this but I am having the same issues.... although it seems that the 202 error mainly shows up when duplexing is involved. On the menu map pages that print out 1 sided they typically come out all right.
  • Anonymous May 11, 2010
    "job recovery" is just that...if a jam occurs, the printer continues the job from the last page printed (last page that exited machine), that's why you get the duplicate page when jam recovery is "on". It will continue to try until it is successful or the job is reset - it can be especially helpful on larger print runs.
    Just thought I'd clarify that, as for the jam, I'm not sure what the cause of that is. I just came across this post and thought I'd clarify.
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: when i try to print a paper i hear 3 rings and
What is the last thing you did before receiving this error? Please follow up.
Posted on Jan 12, 2011
Why does my printer produce a paper jam when printing from laptop but does not jam when copying
When you order a print from the laptop, it gets the paper from the paper tray. When you copy, the paper has a slightly different path it follows to deliver your printed result. Try to put the document in the tray with the blank pages and see if it also jams! Let me know what you find out!!
Sep 28, 2014 | Office Equipment & Supplies
Printer alarms us when a print job has been snet but wont print unless we manualy push the paper size on the printer
You have a mismatch paper size. Document is not same as paper you have in copier. Try printing 8 1/2 by 11 document if doesn't print check printer preferences and adjust settings. Check copier paper trays make sure don't have special settings on them
Nov 28, 2013 | Ricoh Office Equipment & Supplies
Hp laserJet 1022n printing multiple copies when copies are set to 1
Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
Just disable bidirectional support in the printer properties worked for me
Jan 06, 2012 | HP LaserJet 1022n Printer
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
HP 2605dn- replaced all toner cartridges now it won't print-
There might be a problem with the network connection. Is the cable connected to the back of the printer?
The printer could have lost the connection.
If the printer is able to print a configuration page and if the display responds to comands from the buttons in the display panel there is a very good chance the network connection was lost.
Yo mentioned "paper jam" is the printer identifying a paper jam?
Nov 19, 2008 | HP Color LaserJet 2600n Printer
IBM Infoprint 1422 Laser Printer Logo
161 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Toby
Toby
Level 1 Expert
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
