Question about NEC Computers & Internet
NEC 2190UXP monitor problem cant replace with another monitor
We have two NEC 2190UPX monitors which are used for split view ( that is window is spread across both screens) from a remote work station. My wife works at home and will be working between two locations We need to set up the NEC monitor as the prime in each location and use another Mfg. monitor as the secondary at each location. However when I try to connect a different monitor in place of the secondary NEC monitor, I cant get a picture. I have tried two different monitors in the secondary position without results. The monitors are not connected together, instead each is connected to her laptop. The prime monitor is connected to the laptop. Input to this monitor is using the DVI-D and the cable is connected to the DVI of the laptop. Both connections use a DVI having only the long slot pin without 4 pins around it. The secondary monitor uses a cable with a Vega connection to laptop and a DVI connector to the monitor. However this DVI connection uses a Dvi with 4 pins surrounding the long slot pin. I have tried other monitors with both style DVI connections and have also tried replacing the prime monitor with either of my other monitors and still no picture. Both my other monitors have both VGA and DVI ports.I don't understand this. I also don't understand the difference between the two style DVI connectors some with the extra 4 pins and the ones without the 4 pins. The only thing differant is the monitors I am trying to replace the seconary NEC monitor with are not 21.5 in monitors one is larger and one is smaller however they both have DVI input connectors. I am at a loss Any help please Right now I am using the laptop with two NEC 2190UPX monitors and accessing the remote work station. The reason for this question is that I want to setup another office and was hoping to be able to use some monitors I already have for secondary monitors each Since both monitors are connected to the laptop and not each other I would expect any monitor would work as a secondary monitor since they are just reading the laptop video output. I guess I am missing something Or is there something more special about these monitors . Am I beating the bushes and need to use only NEC 2190upx monitors Any information about this would be appreciated,
SOURCE: DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Posted on Nov 26, 2007
  • 44 Answers
SOURCE: Display input
You have to make sure the dvi connection is turned on.
Posted on Jan 21, 2008
SOURCE: connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Posted on Jul 28, 2008
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 32281 Answers
SOURCE: DVI-D cable not working with Westinghouse L1975NW...
If the monitor has two video inputs - a DVI-D and a DSub VGA then the monitor needs to be switched to the DVI-D video input.
Posted on Jan 26, 2010
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
How to connect 3 LCD monitors to a computer
Some cards can send 2 outputs that is split by the cable, which is connected to 2 monitors. Generally speaking though, most just split the image up
If you're not sure if your output supports multiple monitors off one output, it's almost certain it doesn't.
There is USB 2.0 to DVI, HDMI and VGA Multi-Display Adapter
resolutions of up to 1600 x 1200 Allows for effortless multitasking
Jan 05, 2010 | Dell DimensionTM E520 PC Desktop
How do you put a monitor into power save?
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
Jul 16, 2009 | NEC MultiSync FE700 17" CRT Monitor
Distorted shrunken picture
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
My pc has a NVIDIA 7100 graphic card on board, now i want to split screens ( two monitors,one pc) by adding a nvidia 7300 to it. when i do so, the pc takes the 7300 as main graphic card and blocks out the...
better to use 1 video card with dual output, you can split the monitor - separate or different applications on each monitor or you can also extent the application window to the other monitor (useful for spread sheets, applications with timeline, etc.)
Nov 09, 2008 | Computers & Internet
Repair monitor screen
no u cant u simply have to replace your glass of the monitor visit a computer store
Oct 25, 2007 | NEC MultiSync FE991SB 19" CRT Monitor
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Display Image Pinched Vertically
I think this is a non-ddc monitor. But I think you right, the monitor is damaged and won't read it's own driver.
Jul 11, 2007 | NEC MultiSync XV17 17" CRT Monitor
Computers & Internet Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
