Question about Aiptek IS-DV2 Camcorder
Zoom button is pushed in the camera
The top zoom button is pushed into the hole and offset. The button still functions and I have tried pushing it over to line up with the whole but then it won't work. Without a schematic I am afraid to take the back off and attempt to fix it. Any suggestions?
    Genius:
  • 1,269 Answers
The rubber spring for the power button inside the cam has been pushed hard. You need to re-align it.
Posted on Aug 22, 2008
I think I pushed a button [2ND][+], and [ClrAllLIsts]. After that, I tried to draw graphs, but when I push the [GRAPH] button or [ZOOM][5]/[6], it doesn't make any graph! What should I do...??
You do not say that you opened the Y= editor and typed in at least one function and THEN pressed Graph. If you do not enter a function, all you will get are the axes (if the calculator is configured to display the axes.
1. Open the Y= editor.
2. Type in a function EXample y=2X+1 (To type X press the [X,T, Theta, n] key)
3. Press ENTER to validate the function.
4. Press the GRAPH button.
5. If you do not see a straigt line press the ZOOM button
6. Select ZoomSTD
Sep 04, 2011 | Texas Instruments TI-84 Plus Calculator
I need help setiing the time on my adidas adh4004 watch. The manual wont help!
You are right the manual is useless.
To set the watch it needs to be in T1 setting, you can do this by using the C (top right) button, to chose just push once and the number should change, hold to set it to T1.
After that, push the A button (top left), this should hopefully display 'Light'. If it still displays 'Offset' then you are still in T2 (offset lets you offset the GMT). Try the C steps again.
Once 'light' appears you can scroll through the menu using B (bottom left), at which point you should find the time selection option. It should be flasing, use the two far right up and down buttons to then set the time/date etc. Press B to move on to the next setting. When you are done press A.
Nov 02, 2009 | Watches
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Jul 13, 2009 | Kitchen Ranges
SHARPER IMAGE -- M1600 / M1601 Swivel world time clock .
Push the mode button until the top window says 'Alarm', push the up or down button to shut off the alarm, push the Set button to set it.
Mar 05, 2009 | Watches
How do I get a "CAPS LOCK" indicator or light to appear?
Most keyboards now a days usually tell you on screen whether or not the caps lock is on but its possiblbe that when you press the key yowards the left or right hand side a light goes on or possibly in the top center if this is not the case then you may have a faulty keyboard.
Nov 27, 2008 | Microsoft Wireless Laser Desktop 4000...
Card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Feb 26, 2008 | Fuji FinePix 30i Digital Camera
Zoom malfunction
I had exactly the same problem. You just need to smash once with your hand on the bottom of your camera (it looks that this works for all canon cameras).
Jan 08, 2008 | Video Cameras
Enlarged picture
Maybe it isn't the player, but the Aspect button on your tv remote.. Try it. The TV may be in Zoom mode, most new tvs have it.
Aug 17, 2007 | Protron PD-DVR100 DVD Recorder
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Aiptek IS-DV2 Camcorder Logo
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
