Question about Kenwood KSC-WA100 Car Subwoofer
Remote wire do i need to have two remote wires "amp on blue&white wires" or just one?
    Problem Solver:
  • 10 Answers
If it is one sub with one amp, one remote needs to be hooked up. Not familar with your exact set up, but should stay constant for all. The remote signals the amp to turn on power when the deck is turned on thats it.
Posted on May 03, 2009
NEED WIRING DIAGRAM FOR SONY CDX-GT520U
red - ignition switched 12 volt
yellow - constant power 12 volts
black - ground wire
orange - dimmer wire don't use
speaker wires
drive side front
white +
white/black strip -
passanger front
gray +
gray/black strip -
drivers rear
green +
green/black strip -
passanger rear
purple +
purple/black strip -
blue - remote amp turn on wire
blue/white strip - either power antenna or remote amp turn on also
radiorepair@windowtintingin239.com
Oct 30, 2013 | Car Audio & Video
Have a kdc-138 radio which wire do i attach the remote wire to get power to my amp
hi robert, attach your remote wire from the amplifier to the blue/white striped wire of the harness of your kenwood unit. the wire should be labelled "p.cont". cheers!
May 22, 2012 | Kenwood KDC-138 FM / AM Receiver
CD WON'T PLAY THE NUMBERS MOVE BUT NO SOUND AND THE TUNER HAS SOUND?
it sounds like you are using an amplifier. if so, make sure you are using the blue/white wire to turn the amp on instead of the blue wire. the blue wire is antenna remote and turns off when leaving tuner mode. the blue/white wire is amp remote.
Nov 01, 2010 | Alpine CDA-9847 CD Player
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
I NEED FREE DIAGRAM OF CAR STEREO AND AMPLIFIER
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Jun 14, 2009 | Alpine CDM-7854
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
Auto amplifier installation
Does the new deck have a blue wire for remote and a blue/white wire also? The blue one is for a power antenna and shuts of when playing discs or axillary inputs. The blue/white is for power amplifiers and stays on when the deck is on. Also be sure the remote wire that goes to the amp is not pinched and grounded out to the frame of the car. Let me know, and be sure to leave feedback or I don't get paid.
Sep 30, 2007 | Car Audio & Video
Kenwood KSC-WA100 Car Subwoofer Logo
130 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
