Question about Nikon Coolpix 5700 Digital Camera
Spots on image when using built-in Speedlight flash
Sometimes when I take photos I get small, round, hazy spots on my images. They move around form shot to shot and are there wven after I cleaned the lens.
    Novelist:
    Scholar:
  • 79 Answers
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Posted on Aug 29, 2005
SOURCE:
Looking to buy a used pair of pvs 7 nightvision goggles and owner says there are a couple of small black spots when you view is this a cause for concern and what else should i look for ?
Hello, that is normally to have some black spots. Now, if tries to tell that this Military spec. He wrong. Two black spot on any image tubes used by the US Military is rejected, they only allow one black spot and that if everything else is OK. How fuzzy is around the outer circle of the image tube. If there is a uniformed green pattern through out the scope. I would say it was OK. But remember "Buy be Aware". GB...stewbison
Dec 30, 2010 | US Night Vision Ultra PVS-7B Goggles
I have dropped camera once, since after while clicking pictures at night in absolute dark, several round white small circles or spots are appearing on the image.But in full light area and in daylight...
Are these flash pictures? Are the spots in different places on each picture? If the answer to both questions is yes, the spots are dust particles in the air reflecting the flash back into the lens.
Nov 16, 2010 | Sony Cyber-shot® DSC-H20 Digital Camera
I have a Sony DSC T-90 12.1 megapixel. I often
The vertical line can be caused by a very bright object in the image like a lamp or a silver surface reflecting the flash.
The spots are caused by the flash being SO close to the lens. Any object that can reflect the flash reflects it right back at the camera. This is an image problem with most point and shoot digitals. Watch for reflective surfaces and stand at an angle to them. Turn on more lights in the room before using flash. Stand at a slight angle to the image or person you are photographing - don't shoot straight on. (I kneel down and shoot up - makes a good shot too.)
If you are shooting toward the sun, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
Mar 31, 2010 | Sony Cybershot DSC-T77 Digital Camera
Canon A95. Image on screen flashes and is discoloured. Photo same
It sounds bad ccd image chip in your Canon A95 camera and ccd imager chip will be replaced to get correct live view in camera mode.
Canon offers free of cost repair for said problem, click Canon CCD Imager Advisory for details.
Thanks.
Dec 26, 2009 | Canon PowerShot A95 Digital Camera
White cloudy spots on my images - a recent problem
If these are like "bubble" spots and they appear in different places on each photo, I'm guessing you're shooting flash pictures indoors. The spots are dust particles in the air reflecting the flash. This happens on small point-and -shoots because the flash is almost in the same plane as the lens.
Nov 10, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Just changed all cartridgages and photo quality is still bad
scanning
Spots on a scanned
- Glossy photo (original)
- In the high humidity
environment
When a glossy photo is
strongly pressed on the
platen glass, the photo
will stick to the glass,
and the stuck points are
scanned as spots.
- Do not strongly press
the photo on the platen
glass.
- Clean the platen glass
(to eliminate any
moisture).
- Spots appear on
the scanned
image, though
there is no such
spots on the
original
document.
Oct 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
Spots on photos
Hi and welcome to FixYa,
Offhand, similar problem comes only at night/indoor with flash. I noticed that the "spots" would not appear on the image if the camera has been on for a while before the shoot was taken. It is turned on and then shoot with flash, there would be spots; on the other hand, it it was turned on then.....shoot, no spots.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Casio Exilim EX-Z57 Digital Camera
Spots on Image sensor?
put in p mode and go to the sensor cleaning function you need whats called a lens pen it will clean those spots easy just be gentle.
Nov 10, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Coolpix 5700 Digital Camera Logo
183 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
