Question about Dell 1100MP Multimedia Projector
Problem with my dell 1200mp projector
My dell 1200mp projector would come on for a few seconds and go off also the lamp and temp led turns on and starts blinking too. i thought there was a problem with the lamp, so i bought a new one but the problems still persists.
the temp and lamp led come on when i turn the projector on.The fan at the front of the projector also comes when i power the projector.
pls help me cos i need to do a presentation with it tomorrow
  • Timteck May 15, 2009
    So where are the filters? Filters to what? And what do I look for?
  • 38 Answers
This is a very common problem with these projectors. The fans lock up and the units are out of warrenty. The fan you replace it with must be the exact same as the old one, even though it is the same as a 5$ computer fan. The processor will detect the non-dell fan and shutdown in the same way. I Havent been able to find any replacement fans that will work. I may be interested in buying your broken projector from you if you give up.
Email me at: nalexandrov251[A-T]gmail.com and we might be abe to work something out.
Posted on Dec 08, 2009
If you haven't already try cleaninig the filters
Posted on Aug 22, 2008
Why Projector shuts down after turn on after a minutes ? and shows Temp LED and Lamp LED?
the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Aug 07, 2014 | Acer EY.JBY05.005, X1110, X1110A, X1210,...
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Nov 09, 2009 | Dell 1200MP DLP Projector
My remote won't work on my Dell 1200 projector
remote wont click to next page on Powerpoint presentation
Mar 05, 2009 | Dell 1200MP DLP Projector
1200MP DELL Projector flickering problem
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | Optoma HD70 DLP Projector
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
Dell 1100MP Multimedia Projector Logo
912 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
