Question about Vertex iTECH iQfive iQplus Yeasu--VX800 Compatible Two Way Adapters 2-Way Radio
Vertex 800u I have a problem when I turn on radio I get to the channel then radio goes out and shuts off. batteries are fine and secure when put in but when I key up , the radio shuts off.
    New Friend:
  • 109 Answers
This sounds like a current problem which means that the batteries are not providing enough current to the PA section of the radio. It's time to replace the battery. The average lifespan of a rechargable battery is 18 to 24 months. Just because the battery shows the proper voltage does not mean that the battery is good.
Pat
Posted on Aug 25, 2008
Vertex standard charger blinking green
It typically means a bad battery. The charger will still try to put a small amount of charge into the battery at a slow rate. So it may not be apparent that the battery does not have a full charge. Make certain you have the correct transformer. Try cleaning all battery contacts, on the charger, the battery AND inside the radio where the battery contacts are. I use rubbing alcohol and Q tips. If you see corrosion, try a really, really mild sand paper and a light touch! Do not unscrew the contacts on the radio. Let us know if this helps.
Jul 23, 2016 | Vertex Radio Communications
Will transmit but will not receive
I have programmed hundreds of these. The radio may be receiving, but the speaker may be muted. If using a hand mic, have the mic "off hook" or ungrounded and try again. Does the front light flash while the radio is receiving? This indicates the radio is "hearing", just not passing the audio to the speaker. Is there something plugged into the audio jack in the back? Let me know. In 20-30 minutes most shops familiar with Vertex will know exactly what is happening.
Oct 01, 2015 | Vertex Standard VX-2100-G7-45-PKG-1 UHF...
Hi I have a vertex vx2100 radio and I need to know if I can use it as a police radio scanner
Yes. The Vertex VX2100 is a VHF radio which can be programmed to frequencies between 134-174 MHz. You would need to program in the frequencies you are wanting to scan as receive only (no transmit) into the 8 channels of the radio. You would need to acquire the frequencies you need, as well as programming equipment, or take the radio to a dealer for programming.
Best regards.
Mar 31, 2014 | Vertex Radio Communications
Help with Vertex VX-3200 Programming
You may have to find a windows XP or earlier machine. That software doesn't always play well with WIN7
Mar 06, 2014 | Vertex Vx-3200 / Vx-2500 Series Programing...
I have 4 vertex VH-160 radios, two of them have stopped transmitting, all have been dowlaoded witht he same frequencies. Batteries are good. Whe transmit buton is pushed, the is one beep then nothing. ...
The VX 160's may have bad oscillators. It is not user repairable. The simple thing to check are the antennas. Vertex radios are very susceptible to broken antennas and will not transmit. This is true of Uhf and Vhf. Replace one and try it on all the radios. Never transmit without a antenna. It can cause the PA in the radios to fail.
Jan 06, 2014 | Vertex Radio Communications
How do i put a program in to my Vertex Standard VX-929 VHF 136-174 Mhz radio handheld portable transceiver
Nice commercial quality radio. You will need a commercial radio shop to program it. Otherwise you need the particular programming cable and software for that radio to do the job. The fact that you are asking this means that it more than likely it is beyond your area of expertise. If you searched the web for programming software and also programming cable you might succeed . Otherwise order both from Vertex USA, www.vertex.com. Much easier to go to a shop, BTW you need a valid FCC business or GMRS radio license to transmit.
Dec 03, 2013 | Vertex Radio Communications
Can only use one channel on my vertex standard v-231
Hi, again Craig,
Now that I have the Make/Model of your radio, I can give you advice.
You wish to program your set with frequencies, so here is the best way to do so.
Join yahoo group SPECIFIC to your radio MAKE/MODEL, the team there will assist you with great advice and valuable info, plus you can download manuals, diagrams and other great stuff for your radio.
I hope you are happy with my advice.
Cheers,
Peter
Dec 12, 2012 | Vertex Standard Vx-231 Vx231 Uhf...
How to program a Portable Vertex VX-427-4-5 channel?
your post is a little confusing, but let's start with your hand held HH, you can download a copy of the user manual if you don't already have one. I'll get to that shortly,...
Then you ask how to program a frequency/channel into a scanner radio, they are two different beasts.
Also you left out the Make/Model of the scanner, which is a requirement, as no two radio scanners are equally designed.
So with out this info, I cannot assist you.
Now back to the Vertex HH, my advice is to join yahoo group specific to your radio Make/Model, the team there will require as much info as you can provide so as to assist you, you can also download manuals, diagrams and other goodies for you radio, please do not refer to your scanner, as they only deal with your Vertex Make/Model, the scanner is for a different yahoo group, so you can join both separately and kill two birds with one stone.
I hope this info is useful to you.
Cheers, Peter
Nov 25, 2012 | Vertex VX-427 Intrinsically Safe UHF Two...
Nautico 1 keeps going to channel "1a"
Found out it was a low battery. We had charged it for several hours, but it was apparently low. It is supposed to show the low battery symbol, but it never did. We put it new AA batteries instead of the power pack and it worked just fine. Thanks
Jan 25, 2009 | Midland 79-290 120-Channels Base CB Radio
Vertex radio vx 10
Maybe with the drop the radio speake is out of place, did try to open the radio and find if the speaker is in its correct place? The speaker uses a spring connector and this can be out of place. Good luck
Jun 22, 2007 | Vertex Yaesu Radio FTH2009, FTH7009...
Vertex iTECH iQfive iQplus Yeasu--VX800 Compatible Two Way Adapters 2-Way Radio Logo
129 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
