Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Refill string trimmer
After refilling my string trimmer the line will soon get stuck and no longer feeds. it looks like the line gets fused together..any solutions
  • Anonymous Mar 25, 2009
    sorry only saw original answer...i can install but line sticks together after a few uses like its been heat fused
4 Suggested Answers
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
woobie dog
  • 1273 Answers
SOURCE: string is stuck inside reel and I need to remove
Hi, W/D here.
The string tends to get caught in itself, despite our best winding efforts. Pull the spool straight off, and try to get some fingers on the spools as it comes off, in case one of the spools if free, so the line doesn't fly off.
Usually a kinked piece can just be pulled at an angle to free it up.
Best regards, --W/D--
Posted on Aug 15, 2009
  • 3 Answers
SOURCE: how is the cutting string/line refilled or how is
whats the model#?
Posted on Jul 13, 2011
String on Echo (with the 2 strips ) is stuck and cannot get it out on one side? How do I open the head up?
You mean the trimmer line...?
If so. It's run out. Need to rewind new line in.
Press the two tab on the side of the case and then pull the center out to (refill) new line. you should be good to go back in business like before.
Good luck
Mai
May 11, 2017 | Echo Garden
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
Refilling string
Wind in the direction of the arrow on the spool and be careful t seat the spool over the rachet fully.
Feb 18, 2010 | Black & Decker 14" Grass Hog Xp...
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
ARE YOU WINDING TO LINE THE RIGHT WAY ON TO THE SPOOL?? FOLDING THE LINE IN HALF AND WINDING BOTH ENDS OF LINE SAME WAY? NEIL
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
148 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
