Question about Dell Inspiron 6400 Notebook
Dell laptop charger
Today I was on laptop and everything was fine. I went outside in plugged charger into outside outlet and now it doesn't charge. It doesn't show its green light and it has a beeping noise. My Dell Laptop charger was working fine until one day i saw that the charger was plugged in the charger and jack but not charging the laptop. I checked the charger, and saw that the Green light was turned off. I unplugged the charger and plugged it in again. I saw that the green light turned on for a second and then turned off. and it is not working anymore. I know that the problem is with the charger because i tried using my brother's laptop charger and it was working just fine.
Is there any way to fix it? or i have to get a new one? and if i need a new one where can i get it from?
  • Anonymous Oct 10, 2008
    I have the same problem...and don't you suppose its when I need my laptop the most. I've got a paper to write for college and my laptop just went dead. I've had nothing but problems with this computer. I don't know what to do anymore...
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Posted on Oct 31, 2009
    Genius:
  • 2,028 Answers
Unfortunately there is no way of fixing the charger, you will have to get a new one. The cheapest place to get chargers (AC adapters) is on Ebay. This is where I get all chargers for my shop. They have many vendors that just sell chargers, and looks like one for the Insp 6400 runs about $20.
Posted on Aug 22, 2008
  • 4 Answers
I had this problem. I slammed the charger hard against the kitchen counter. I did it several times, using several angles. I did it while the charger was plugged in and beeping. Suddenly, it stopped beeping and the light came on. I'm sure it's still a fire hazard, but if you have a deadline to meet, just don't forget to unplug when you are done.
Posted on Jul 25, 2010
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
When I plug in my Dell Inspiron 1521 laptop, I get an error message saying it does not recognize my charger, will not charge and will likely slow down my computer's speed/performance. Everything...
Same topic on Dell official community, may it will help.
http://en.community.dell.com/support-forums/laptop/f/3518/t/7311465.aspx
There is high possibility that your adapter is stuffed. Dell have built in a recognition circuitry into the 65w adapters and when that goes, the system will no longer recognize it as a 65w adapter even though it is still putting out 65w. The system then shuts off the battery recharge circuit and to make matters worse it won't even charge the battery when the computer is off. It also speedsteps the processor down to half its speed so everything runs slower. Only option is to stick with a slow computer that can't be used on batteries or buy another ac adapter.
If you do not want to pay $80 for a original adapter directly from dell, there is an alternative choice to get an 3rd party charger, check this link below:
http://www.chargerbuy.com/replacement-dell-inspiron-1521-ac-adapter-19-5v-3-34a.html
Aug 02, 2011 | Dell Inspiron 1521 Laptop
When I plug the charger into my Dell Inspiron 1521 laptop, it gives me an error message saying it does not recognize the charger. The charger is only two months old and was working fine just last night. ...
First thing to try would be the work mate's charger again to see if it still charges. If it does? That rules out any issue with the battery.
Next, I would clear the cmos.
To do this? slide the battery out using the 2 slide pins. Unscrew the memory door, then unplug the cmos battery held within. Replace after a couple of minutes.
Now try your charger again.
Apr 02, 2017 | Dell Inspiron 1521 Laptop
My Dell Laptop was working fine in 220V country, when i moved and try to use it in US (110V) the charger LED is ON but once i plug it in the laptop it goes off and the laptop is not working. i even tried...
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Jul 15, 2017 | Dell XPS M1330 Notebook
My Inspiron 6000 won't charge the battery.
According to your problem, this may occurs for either the battery of your laptop or the charger is faulty. First check electric outlet where you have plugged your laptop charger is OK. Then check the power cord. If everything OK then you have to change the battery.
Jun 10, 2011 | Dell Inspiron 6000 Notebook
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
I have a Dell Latitude D630, and I have had it for less than a year, and my charger is broken. I have it plugged in and everything, and it is not working. I plug the adapter into the outlet, and the...
sorry, i have to say this-- make sure the outlet works-- or try out a different outlet. :-)
ok, then make sure the connection is tight between the 2 parts of your adapter, it may have come loose.
other than that, you have a dead adapter. laptop companies are very good about replacing them for free under warrantee. they dont want fires starting at someones home because of a 30 dollar part.
i just called my laptop company, hp, 1 week before my 1 year warrantee ran out, and they shipped me a new power adapter, free, overnight.
call dell, tell them, they'll ship you a new one with usually free shipping, and usually in a day or two tops to your door.
Jan 31, 2009 | Dell Latitude D600 Notebook
Dell laptop charger
First try starting the machine without the battery, only the charger, Then check the charger with an ohm meter to see if it's working properly. The out put readings are listed on the charger. In case of a surge, the charger is designed to go out first before damaging the system. However, this is not always the case. If the charger checks good, then you should take it in for a professional diagnostic because the problem may be with the power management system on the motherboard. One thing to keep in mind for future reference is when moving to a different location with your laptop, when unplugging the charger, always unplug the charger from the laptop before unplugging from the wall socket, and when plugging in, always plug the charger into the wall socket before plugging into the laptop. This will keep from surging your system.
Jul 16, 2008 | Toshiba Satellite A45-S250 Notebook
Dell Inspiron 6400 Notebook Logo
4,704 people viewed this question
Alun Cox
