You may have a plugged drain hose. Or possibly your household drains are running slowly. To check the hose, pull the washer out. Turn it off and unplug it. Disconnect the drain hose (the 2" black hose) and see if you can clear it of any clogs. You will need some towels and a container for catching any water.
Leave the washer unplugged for a time (don't get the plug wet) while you check other drains in the house, especially the garbage disposal and toilets.
Plug the washer back in and turn it on and try a cycle.
This is the most common problem for what is happening with your washer. If this does not fix your problem, you may need to call a serviceman, or if you do have slow drains elsewhere, a plumber.
Thank you for uisng fix ya! I would appreciate a rating on this solution.
Was this helpful?
Yes
No
Popular Solutions for Hoover AL120 Front Load Washer
machine takes in water intill the drum is full then drains taking soap with it than fills up again...
(More)
machine takes in water intill the drum is full then drains taking soap with it than fills up again the drum is then very heavy and make a screching sound and then drains again. put it on a second time and it washes but takes in very little water and machine will be on for an hour and a half.
Push button control panel has come loose and dropped inside the washer compartment. How do I take it...
(More)
Push button control panel has come loose and dropped inside the washer compartment. How do I take it off and reattach?
The door hinge has broken & needs replacing. I can get the part easily enough but do not know...
(More)
The door hinge has broken & needs replacing. I can get the part easily enough but do not know how to fix it to the door. I have removed the 4 screws close to where the hinge fits but am not able to get to where I need to be to get the broken bits out and the new hinge in. Any ideas??
Hi I have a Hoover AL120 machine which has developed a fault. As soon as the machine is switched on...
(More)
Hi I have a Hoover AL120 machine which has developed a fault. As soon as the machine is switched on - no matter what cycle is chosen or whether the dial is set to 'stop' - the pump runs and doesn't stop. Nothing else appears to happen. It is as if the machine is waiting for a signal from the pump to say it has finished pumping. What I really need is an electrical schematic for the machine - does anyone know where I can get one of these? Many thanks in advance M
Hoover 120 AL When I use program 4 the machine will not continue after reaching the stop sign...
(More)
Hoover 120 AL When I use program 4 the machine will not continue after reaching the stop sign between 4 and 5. If I turn machine off and move dial manually on to position 5 it will continue but stop at 8 or 9 . Turn it off and move dial manually it will continue to end of cycle
