Question about Whirlpool Washing Machines
The temerature settings for washer are wrong. I sporadically get very hot on cold. cool on warm. hot on cool. etc.. It is supposed to be an all cold rinses wahers
    President:
  • 1,462 Answers
If this is a machine with hot and cold hoses connected, check they are the right way round. don't rely on what your hose plumbing says.
to check, put on rinse and if hot water flows in, then hoses are the wrong way round
Posted on Aug 22, 2008
What is the temperture range hot/cold
This machine is energy compliant to an extreme. The installation says to have the water heater set to 120 and when you put the machine on HOT it will be cooler than that because it mixes the hot with some cold. WARM is a little more cold and COOL is mostly cold and some warm, COLD is just plain cold.
Sep 02, 2015 | Estate ETW4400TQ Top Load Washer / Dryer
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
IS A HOTOINT FRONT LOADING WASHER TYPE WF860G [SUPER SILENT] MODEL A HOT/COLD FILL OR COLD FILL ONLY.
This model like most new models are cold fill only.. It will heat to the temperature set by the variable thermostat setting..
Dec 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Washing Machines Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal De
