Question about D-Link AirPlus DI-614+ Wireless Router
Secured wireless network
How do I set up a secured wireless network for the DLink DI-614+ router?
    Master:
  • 441 Answers
SOURCE:
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
How do I access the router control panel?
The factory default User name is admin and the default Password is blank (empty). It is recommended that you change the admin password for security purposes. Please refer to Tools>Admin to change the admin password.
You need to download the user manual. ftp://ftp.dlink.com/Gateway/di614+/Manual/DI-614+_manual_06292005.zip
May 01, 2011 | D-Link AirPlus DI-614+ Wireless Router
Can not connect to internet thorough my dlink 614 router It tells me the internet security key is incorrect even though i know it is not
Please access the web interface of the router and confirm the security key. Also, you can try to change the security key. It can be a possibility that your computer is not synchronizing properly with the current security settings.
If you find that you are putting the right security key then please change the security type to wep 64 bit or wep 128 bit and configure a new key. Also, change the SSID or the network name and try to connect.
In case of any issues please let me know which windows you are running and the security settings on the router.
Thanks,
Rashish
Aug 09, 2010 | D-Link AirPlus DI-614+ Wireless Router
The network has come up as an unsecured network/connection, can u help us with setting up security?
log on to the router
go to wireless / security
Set the security to WPA2 if possible
choose a password
Here is a nice how-to guide http://support.dlink.com/emulators/di514_revc/h_wizard.html
Aug 05, 2010 | D-Link DI 514 Wireless Router (DI-514)
Unable to write network settings to device error code 0x8004d112
1. this error is not recognizable.
But here is the D-link site for updating your firmware for the DI-614
this may resolve your issue.
http://www.dlink.com/products/?pid=DI-614%2b
2. You also may want to check the status of you router by logging into it and checking the "status" page (192.168.0.1)
User : admin
No password unless specified
This will tell you a lot as to what the router is doing and not doing.
Jun 18, 2010 | D-Link AirPlus DI-614+ Wireless Router
Reset dlink 614+ router, forgot password
I don't know for the 614 as there isn't a model like that... Your picture shows a DI-514. Here is the process for that model.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
If you truly have a 614, can you post more about the model number? It's usually written on the bottom of the router.
Aug 30, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How to put a password on dlink dir-300 wireless network
u have to setup as wep
then enable secure network then set encryption key.wihc is prompt for connect network.
Dec 30, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-614+ Wireless Router Logo
141 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
