when I turn the printer on I get a message initializing and it stays there. I can not turn the...
(More)
when I turn the printer on I get a message initializing and it stays there. I can not turn the printer off and it will not work
The envelope alignment on my HP PSC 1610 All-in-One is off. Have explored the following: Envelope...
(More)
The envelope alignment on my HP PSC 1610 All-in-One is off. Have explored the following: Envelope Options: envelope size and manual delivery/return address settings; Printing Options: feed method; Printer Control Panel to restore factory defaults, check set language and country regions; Checked all connections, dis/reconnected and rebooted computer...without success. Top left return address shows only 2 numbers of the zip + 4 code. An 8 x 10 sheet of paper shows both the return and delivery address perfectly aligned to the bottom right of sheet. How do I realign the printer to print a size 10 (4 1/8 by 9 1/2 in) envelope?
My HP 1610 has a yellowish section over half the page when I scan and a faint gray area when I...
(More)
My HP 1610 has a yellowish section over half the page when I scan and a faint gray area when I print a black copy.
Ive just installed the software and although it goes through the printing goes through the process...
(More)
Ive just installed the software and although it goes through the printing goes through the process there is no ink on the pages although the ink cartridges are full. it says there is no connection.
