Question about Asko Washing Machines
My Asko model 20005 washer does everything normal except it will not spin. I assume the problem is the control board but would like to if there is other possible reasons for the no spin. Thanks
  • 351 Answers
Is it draining,check the buttons on the front for no spin option.this is an old model and the parts are expensive
Posted on Aug 27, 2008
I have an Asko 20005 front load washer. When the humidity is high, it buzzes but will not start. When I run a dehumidifier for a few hours it works fine.
The humidity will kill the control unit if you keep trying to start when buzzing. Make sure the humidity is as low as possible. These controlunits are discontinued, and impossible to get as sparepart!
However, this is the best machine ever made!!
Jun 28, 2014 | Asko W6021 Front Load Washer
Asko w620 washer will not agitate or spin
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Nov 24, 2013 | Asko Washing Machines
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
Good luck! And make sure the thing is unplugged before you work on it!
Apr 04, 2011 | Asko W6021 Front Load Washer
Hello, I have an Asko washer model 20005 leaking water from both heating units where they attach to the drum. Both have been replaced and "not overtightened" by repair person, but still leak...
Only one answer really- recall the 'repair person'. He or she should have carried out the repair properly and completely and ensured that there were no leaks from the units after replacement. That's what you pay for.
Maybe they used the original washers and not new ones, for instance? Are both heating units 'OEM', that is Original Equipment Manufacturer (Asko or whoever actually makes the washer) or less expensive 'copies'?
Put pressure on ;-0)
John C
Mar 05, 2011 | Asko Washing Machines
Where can I purchase a pump for my Asko washer 20005?
Ok, i have located the pump you will need. Simply click the link below to be directed to the purchase page.
Nov 04, 2009 | Washing Machines
Kenmore 110 Spin Cycle
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Sears parts site:
Enter your model number and you'll see a number of sub catagories for the washer components.
Whirlpool Installation and maintenance PDF.
This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.$FILE/L-55.pdf
Sep 21, 2009 | Kenmore 22642 Top Load Washer
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Follow up to asko w6021
try replacing the pressure switch i have had this fault before.the rear sensor supplies the correct water level,the front switch controls the heating and spin cycle.keep me posted.Iwork for asko i will speak to tech support on monday and let you know thanks.
Mar 29, 2008 | Asko W6021 Front Load Washer
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
151 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
