Question about Zebra Eltron P310I Thermal Card Printer
Not printing in color
I just got a new computer - when printing the the first time it was in black and white - what am I doing wrong?
    Master:
  • 441 Answers
The the color settings on the printer properties, maybe it set to print black and white only or the printer may not have ink on colors
Posted on Aug 22, 2008
Printer will not print in color, only black. We just replaced the cartridges.
If its an HP inkjet printer you may have set it to print in black and white. To change this setting go to "control panel", then "printers and devices", right click on your printer, then "printing preferences", "advanced", then uncheck "print in greyscale"......Good luck !
Nov 03, 2012 | HP DeskJet 932c InkJet Printer
I had been out of color ink for a few months, so just printed using black&white mode. I installed a new color cartridge, and the computer is not acknowledging that a new cartridge is in. It will only...
Start, control panel, printers, your printer, printer preferences, advanced. Uncheck the complete-a-print boxes and also check to make sure the print in black & white box in unchecked.
Rick
Sep 12, 2011 | Dell 926 All-In-One InkJet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Wont print in color only black and white
wrong cartridge or needs cleaning the contacs
Dec 15, 2009 | HP DeskJet D2560 InkJet Printer
Can't select to print in black and white
when you do a "file" "print" to print the form - click on "preferences" in the print menu - then select "grayscale printing" box. this may have to be done each time you go to print something new
hope you got your taxes done already
Apr 14, 2009 | Office Equipment & Supplies
Color photo printing
On the menu tab for 4X6 ,under effects ,you have selected black and white or grayscale
Apr 02, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Printer won't print color!!
Hi hofhofhof, it sounds as though you may have the wrong settings in the print driver window. Check to see if it is set for B&W (or black only) and also check to make sure the paper size is set correctly. You may have to do this each time you do a new print job.
Oct 25, 2008 | Canon PIXMA MX310 All-In-One Printer
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Printing black and white.
Go into printer, properties, and printer quality.  You will be able to find the b&w, or (grayscale), and just check it.  And unfortunately, your model is one where you have to go in to change every time you print at different times...meaning if you print one after another, you do not need to recheck:)
Feb 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Zebra Eltron P310I Thermal Card Printer Logo
98 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
