Kyocera Mita KYOCERA/MITA - KM-C3130 Printer Logo
A
Anonymous Posted on Jun 24, 2011
How to scan on kyocera km-c2230 I want a simple
How to scan on kyocera km-c2230 I want a simple way like scan printer to pc
1 Related Answer
Anonymous
  • 268 Answers
  • Posted on Oct 02, 2008
SOURCE: Service manual for a Kyocera KM-C2230 Copier?
Here are the manuals associated with that copier: http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=13007&pcat=10565&rcid=10009&rscid=10028
Hope that helps you out!
How do I add a destination PC to the Kyocera KM -1650 and the machine will accept it
install scan file utility on the new pc and then configure it.
then add that pc to the address book of the scanner
My Kyocera KM-1650 has been relocated and now the scanner won't work but it stills prints on the network.
u need a software called scanner utility to be able to scan to a folder on the pc u connected to.Unless u scanning to e mail then ur new server has different network details
2helpful
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
1helpful
2answers
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2answers
I have a 100 error from kyocera. How i resolv?
An error code of A 100 indicates a problem with the main scanner. Unfortunately this usually requires replacing components of the machine. You will need to call a repair technician to take a look at this.
It could be something as simple as a loose connector on the main board, the exposure lamp could need replacing or a board might need replacing. All of these things should be done by a technician.
Henry
7helpful
2answers
Kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
2answers
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
I have Kyocera Mita KM-2050
you need to get the i.p address of your scanner and access it from your browser.
on the bottom left of the command centre menu you will see SCAN TO PC  "destination" .
put your details in new screen. if you are using a static i.p address for your pc put that in.
if you are running dhcp you should use the host name of your pc
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Bill Eager
Norman Weimar
Norman Weimar
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
