Question about Daewoo DTQ-27S3FC 27" TV
Black rectangle appears on every channel
I turned my television on and a 18 by 12 black rectangle appeared. I've tried turning the tv off and then on, and it still comes back. I cannot get rid of it. Help! How can I fix the problem. The kids have misplaced my remote. I have no idea where it is.
  • 417 Answers
somehow your closed captioner has been turned on and within that the text option has been turned on. If theres a menu button on the front of the tv you can navigate with the menu button and either the volume or channel buttons to select options and then navigate to closed caption and turn it off. If you dont have a menu button you will have to get a MID priced universal remote which will have your menu button programmed within it, some newer directv remotes have the menu function, you can go to radio shack and tell the guy there your problem and he will will most likely set you up with the proper universal remote which will enable you to shut that off.
good luck!
J
Posted on Aug 22, 2008
SOURCE:
Black rectangle appearing in lower half of screen on 32" Aquos
did you turn off the close caption settings in the set up menu.
Sep 15, 2012 | Televison & Video
I get a black rectangle in the middle of the screen. I can click any button (mute, view mode, cc) and the black rectangle will go away and whole picture will appear, for a couple of seconds and then the...
I do know that on Zenith CRT televisions of the 1990's this will happen and all I did to fix it is to go to the menu and turn the text feature off. This may be true with your Sharp as well.
May 21, 2011 | Sharp Aquos LC-32D40U Television
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Jan 10, 2008 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Black Rectangle Appears on Screen
Perhaps the caption is on?
May 27, 2007 | JVC AV-27220 TV
Daewoo DTQ-27S3FC 27" TV Logo
113 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
