An error message of "for the best resolution change your settings to 1440 x 900. However these are my setting and the error populates appx every 5 minutes in the middle of the screen and does not go away for appx 5 seconds. We have a HP Pavilion a1726x
    Master:
  • 441 Answers
Usually this pertains to the maxium resolution of your monitor-make sure the resolution on your graphic card is set to the same 1440 x 900, or else the monitor will ask you to change it to back to the 1440 x 900.This also includes games, make sure you set your game resolution in 1440 x 900, if its not possible then check the manual of your monitor and then see if there is a auto resolution option.
Posted on Aug 22, 2008
SOURCE:
NECT VT465 error message "out
You'll need to change the resolution of your laptop and/or PC, and make sure to set the refresh rate to 60Hz.
Sep 14, 2011 | NEC HT1100 Multimedia Projector
When I boot up my computer, it will pass the bios screen and "loading windows xp" screen, but gives me an error message saying "Out Of Frequency Range, Set reaolution lower" and will...
As you computer boots up, press the F8 function key several times. Then select boot up in Safe Mode - go to Control Panel - Display - Settings and change the screen resolution lower such as 1024 X 768 - Apply and Shut down computer.
Reboot the computer.
Jun 03, 2011 | Computers & Internet
I get "Out of Range" message. What is this?
The monitor resolution settings has been changed.
please set the resolution settings to defaults in the monitor
Jan 27, 2011 | ViewSonic VA902b 19" Monitor
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Nightowl 8500 500 GB harddrive 8 camera system. I could see the video right out of the box. Set up the VGA cable to a 1080p tv. I changed the video resolution to the highest setting and my 1080p tv will...
The only way is to connect it to a vg computer type screen and then get in the menu if you changed the resolution on your tv you should then get in the tv menu and changeit there
Sep 28, 2017 | Night Owl Optics Night Owl FALCON8500...
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Resolution message
Right click on your desktop and choose properties. Click on the settings for your problem monitor and you should find the option to change the screen resolution.
Feb 28, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Open Questions:
Computers & Internet Logo
83 people viewed this question
Ekse
Alun Cox
