Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Icemaker not working #106.56546401-sn:ss5058182
Not getting water to icemaker, I replaced the water valve assembly also cleared out the water lines. Still not getting water to the icemaker.
  • eamarkasky55 Sep 28, 2008
    It seems like after I changed the water filter the ice maker quit making ice. I still get water from the water dispenser. Could something have come loose?
  • 958 Answers
SOURCE: no water is going onto the ice maker (Maytag Model # MZD2766gew)
the water solenoid valve is normally triggered by the ice maker itself. as it turn to harvest the ice, it should trigger the water solenoid valve to start another cycle of ice making. its either a wire harness problem that's why power is not getting to the valve or the triggering switch of the ice maker not sending power to the solenoid. i hope i was able to help you guys...
Posted on Feb 18, 2008
aborcass
  • 2651 Answers
SOURCE: water coming out door and into icemaker
welcometo the world of FRIGIDAIRE!! only company i know using that DIODE within the harness, im unable to lok up the part number for the DIODE kit, there are 2 of them, i would call the manufacture and ask them to supply you with number... just seems a ltiile wierd that ice maker fill troughdoor andyour water fill the ice machine, i see that you tried switching wires and lines still thesame result, please excuse the silly question but did you try to just switch the wires to the dual valve??? not worrying abouth the lines. just askin.
Posted on Mar 22, 2008
SOURCE: U-Line 95
I have a BI95 on my boat, same problem, got it diagnosed today, the ice mold is deteriorated and leaking, see if there is any white plastic coating that is coming off. If so, you have to replace the entire ice maker unit. You won't like the cost.
Posted on Jul 15, 2008
Krazytech
  • 725 Answers
SOURCE: icemaker
There is a water fill adjustment on your ice maker the normal fill time is 7.5 seconds...
the adjustment screw is on the side and in the middle of the head..
•Turning the water level adjustment screw
will move the contact in its relationship with
the contact ring segment. This causes the
contact to vary the time that the water valve
is energized since the contact ring is tapered
at the end of the fill time.
•Turning the knob or screw clockwise
decreases fill - counterclockwise increases
the fill amount.
• Only one revolution is possible with the
cover on, due to a stop molded on cover
360o will affect fill by 40cc - 180o varies
the fill by 20cc.
•if you need more adjustmnet remove cover
• Further adjustment could damage
module.
Hope it help please let me know if it does...
Posted on Sep 03, 2008
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
The icemaker isn't working. The water line is hooked up and working fine when I want to get water, but the line isn't feeding water to the icemaker in the freezer.
HI. testing is needed at this time. There are some issues that concern the operational value of the inlet assembly. check the lines to make sure that they are not frozen. If the line that feeds the ice-maker is ok, and not frozen, proceed with the testing of the inlet assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Nov 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
No water to door or icemaker on KSSS48DBW00
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 22, 2009 | KitchenAid (KSRD22FKST) Side by Side...
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Neither dispensor or icemaker works after replacing water lines
Feb 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool icemaker
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker does not work there is water to it but it doesnt run in
Jan 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not working, freezer not getting cold enough....
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My icemaker is not working
Jun 30, 2008 | Frigidaire GLRS237ZA Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
121 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
