Question about Whirlpool Dishwashers
Dishwasher stopped washing just making a humming noise
    President:
  • 1,462 Answers
Humming noise is the wash pump energised but not turning.
this can be:
wash pump seized up
foreign object stuck in the pump impellor.
pump capacitor faulty - a common fault. if pump turns freely by hand but not when energised, then the fault is probably the pump capacitor - cheap part
Posted on Aug 22, 2008
SOURCE: Loud Whining/Humming noise while washing
I've got the same issue with my whirlpool dishwasher, model GU1200XTLS. If I find out anything, I'll let you know. Have you received any insight?
Posted on Feb 25, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
  • 65 Answers
SOURCE: very noisy wash cycle
most times i have found a foriegn object in the pump. sometimes the machine will clear it itself but other times you have to take the pump apart. it is not too difficult but you will need a size T15 and T20 Torx aka (star) bit to get it apart. Just keep taking out screws until the filter flowplate lifts off.
Posted on Dec 10, 2009
SOURCE: Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Posted on Feb 05, 2010
Dishwasher wont wash! just makes a humming noise
Without knowing the brand and model it makes it a little hard to anser but I can tell you thats the typical sign that there is something wrong with in some machines, the pump/motor assemble, in others the recirulating pump, but a technician should be called.
Apr 29, 2012 | Dishwashers
Ge dishwasher dont wash
i think this is a simple answer;;your dishwasher has a piece of glass in the out pump or something else.remove and you will find it will be ok adriqan.;;;;
Jan 20, 2010 | Dishwashers
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Dishwasher makes a humming/rumbling noise when washing but stops when the water drains.
As the machine gets older, it may start to make other noises due to wear on the various parts. If the machine is working well, leave well enough alone.
Oct 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 | Dishwashers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Dishwashers Logo
639 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
