Question about Logitech QuickCam Pro 5000 Webcam
Quickcam will not work can i delete all and start over again
Khkml
Posted on Sep 07, 2008
I have a Logitech quickcam communicate deluxe and when I try to use it with a web based chat program on firefox, it crashes. Any help is appreciated.
uninstall logitech quickcam when it done restart your computer/ install logitech quickcam again if not working maybe your camera have a problem.
Feb 23, 2010 | Logitech QuickCam Communicate Deluxe...
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
My QuickCam Pro 9000 is not working because my computer was restarted by mistake. now i can't use my camara
try to unplug the webcam. start your computer again then plug it again if you prompt to insert a software disc insert it and follow the step by step instructions. then restart. hope itll help!
Oct 02, 2009 | Logitech QuickCam Pro 9000 Web Cam
Windows Startup with a blank screen after quickcam software
Hmm. It seems as if the driver isnt compatible with your hard ware! (sounds very stupid i know) This could be your graphics processor, motherboard,web cam or simply a combination of all three. Id recommend seeing if you can get hold of quickcam software from another vendor.(Just to ensure its not the software version.
If that doesnt work them im pretty sure that your laptop will not support it.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=33739&lc=en&dlc=en&cc=us&os=228&product=92994
Sorry to be so blunt. If you have the time maybe you could try a fresh install then install quick cam first. If it still goes black screen it wasnt meant to be.
Sep 02, 2009 | Logitech QuickCam Sphere Webcam
I would like to down load and install it again on my computer the
System restore would bring bring back your system to life...START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE and then restore your system to a previous date when it was working fine.
As far as freezing is concerned it could be a hardware problem too...try removing any external device attached,make sure your BIOS specification is according to your motherboard...read the manual. It could also be a video card problem.
Try re-installing windows...at the end of the day,this step usually does the work.
Aug 14, 2009 | Computers & Internet
Logitech quickcam
have u tryed to go into the program files and clicking on the icon to run the webcam if it works then u need to delete the old one and use the new one
have u tryed updating it
if all fails then reinstal it
and sort out the settings
Jan 27, 2009 | Logitech Quickcam Chat Webcam
Can't get Logitech QuickCam Pro 9000 to work on Gmail?
I had this problem but I fixed it. The google chat uninstaller does not uninstall everything. Go to the hidden folder Application Data of the default or local user in the Documents and Settings folder of the C drive, you will find the plugin folder for google chat. Delete it and then reinstall the plugin and it will work.
C:\Documents and Settings\Joe\Application Data
Jan 19, 2009 | Logitech QuickCam Pro 9000 Web Cam
Restarting the computer
Normal 0 How much memory do you have installed in your computer? It may need to be increased as this is likely to be the cause of your computer freezing.
Hope this is of some help. Bud
Jul 03, 2008 | Logitech QuickCam Connect Webcam
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
Logitech QuickCam Pro 5000 Webcam Logo
15 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
