I need a replacement lamp for my Samsung HLR 5067. The old lamp is a bp61-01025A, but I was told that the replacement bulb is a cross-referenced bp96-00826a. I tried it but the housing unit seems to be bigger. My question is, can I remove the new lamp and put it in the old housing? Thank you
Hello...... what is the modle # color wheel the Samsung HRL 5067 WX/XAA? I have not pull the old one out. I look everywhere and I found everything except the one that matches that TV. Could anybody help? I...
Model number should be HLR 5067 Color Wheel PN# BP96-00674A
Encompass Parts has them for $147.11 1-800-638-3328
Samsung 1-800--627-4368
You can also look on Ebay under Electronics/ TV Parts
Jul 26, 2011 | Samsung HLP5067W Television
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
My hlr 5078 wont turn on it gives me 3 blinking lights
CK the Lamp Fan if it stops running Lamp will shut off, and Ballast board is what turns Lamp ON
If Fan is OK Look at Ballast board it connects to Lamp Plugins. Encompass Parts Distrubtion List Parts/Prices for this TV 1-800-638-3328
Let me know if you need any more help.
Mar 21, 2010 | Samsung HL-R5078W 50" HDTV
Samsung hlr 5067
Replace Ballast Board Call Encompass 1-800-638-3328 or Look on E-Bay they have some good deals on New and used but works #BP96-00690A I checked they have them in stock for 64.40 Visit there website Encompass Parts Distirb.
Sep 28, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Green vertical stripes over marginal picture
sounds like screnn is faulty, hair line crack will do this - if still on warranty send it back-or some hse.insur. will cover the cost of a new t.v. to the same value.
Aug 07, 2009 | Samsung DLP HL-P5663W 56" TV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
I've got a replacement lamp for a Samsung HLR 5067. The old lamp is a BP610125A. I was told that the new replacemet lamp is a BP96-00826A. The problem is the new Lamp's housing seems too big for my Hd...
I have the same bulb and was told by Replacement Lamps the same thing. No you can not switch the housings. I tried. The bulb is too large and does not fit in the old housing. It is the wrong lamp all together.
Aug 22, 2008 | Televison & Video
Sudenly turn off -Samsung 5067
On my samsung hlr6167 dlp,it was the signs of a lamp going bad/defective. Replaced the lamp and the problem is gone now.
Apr 12, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
877 people viewed this question
Top Televison & Video Experts
