Cars & Trucks Logo
Posted on Jun 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buzzer sounding sporadically while driving...no warning lights illuminated. what could be the possible source of this issue? The problem started after air conditioning condenser was replaced.
Anonymous
Level 3:
  • Master 2,006 Answers
  • Posted on Jun 24, 2011
Anonymous
Master
Level 3:
Answers
2006
Questions
Helped
593135
Points
6261
On most vehicles you will hear a buzzer when the car is in gear and a door is opened. Could have a wire (hot or ground) gotten disconnected in the condenser replacement?
No more buzzer warning sounds
Cocking time ? Cocking what ?
When I start my car, and start driving, the warning buzzer starts sounding, for quite a few minutes, then no warning buzzer for a short while, then starts buzzing again
the buzzer may just be a reminder to make you look at the dash to see that warning light.
You may need to get the dealer to have a look at it.
Sorry that isn't a solution, but something is better than nothing.
Official youtube website 2006 lincoln town car
Which warning buzzer? Seatbelt? Door Ajar? ???
Clio cut out while driving and now won't start
If it made a 'whurring' sound instead of the normal cranking it may have broken the timing belt. If you continue to attempt to start it the valves and head could be damaged. I recommend having it towed to your mechanic
2004 4runner ABS warning light in mornings
When a warning light is on, codes are stored. Get the codes read. That's your starting point. Asking us to guess is a waste of time
4helpful
2answers
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
