Question about Nikon Coolpix 2200 Digital Camera
Red box, white circle
This is flashing middle right side screen , how do i get rid of this , i must have set something. thanks Larry
  • 876 Answers
There are many icons listed for your camera in the manual. If you do not have the manual you can download it online at It is a little hard to locate, but it is there and it has diagrams of all the icons and what they mean. If I can I will try to send you a diagram.
Posted on Aug 22, 2008
How do i turn on the flash?
On the menu there should be an icon that looks like a yellow lightning bolt with a red circle around it and a red line thru it (this means that the flash is off) the lower right hand corner you should see a white lightning bolt. Tap the red circle 2 times and you should notice that the yellow lightning bolt now stands alone and the red circle and the red line has been removed (now your flash is on). Note: Each time you turn on the camera and you need flash, you will have to make this adjustment...I hadn't figured out a way so that it happens automatically..
Apr 11, 2011 | Vivitar Cameras
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
While driving a little black box dropped down near my brake peddle ,so I pulled off the road and tucked it back under the dash, it is about 2in X 5in and about 1 in deep,with a rounded circle on it...
Thanks for using FixYa!
What you found is the alarm module. Just tuck it back in securely. Nothing to worry about right now...
Have a great day.
- HotRatchet
Jul 28, 2009 | 2003 Nissan Pathfinder
I just bought and installed a Frigidaire Affinity four prong heating cord and when I turn the power on through the fuse box, the dryer lights up, allows me to select the drying options but does not have...
you should have 4 wires / red, white, black and green / red and black goes to the outside temmals and white to middle and green to cabinet / check and see if you have it connected that way / larry
Dec 04, 2008 | Frigidaire GLEQ2152ES Electric Dryer
No Sound
sounds like you are using componant cables.[ red,blue,green on the right side in back of the cable box for the picture, & red & white cables for the sound.] make sure the red & white cables are connected to the middle white & red outputs of the cable box to the tv's red & white inputs, not outputs. hope this helps.
Feb 06, 2008 | RCA D52W15 TV
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Audio box flashes on screen {mono/stereo}
For some using composite wires instead of the coaxial may not be a possible because you use the red,white,and yellow spaces for your xbox or playstation. Here is another solution if you use digital cable or a similar cable box. This may work for many other cable boxes. Go to your cable box's settings and look for an option to change your "Audio Range". which is probably right now set on either "normal" or "narrow". If this option is on "narrow" then change it to normal and monitor the results. If you continue to recieve this problem then change the setting again to "wide". This should eliminate the box all together. If anything you might only see it once or twice in the entire day instead of ever 20 secs like mine was. I sincerely hope this is helpful.. Let me know.
Nov 12, 2007 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Screen now has 3 small boxes in middle - one red, one green, one white
Its easy to fix and cheap. Check for chip kits.
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Nikon Coolpix 2200 Digital Camera Logo
87 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
