SOURCE: I recently purchased a Dynex
Sounds like the power supply is not compatible with the motherboard. If the motherboard can't support a 400 watt powers supply you will either get a blinking light or nothing at all. Those optiplex's use a proprietory power supply because of the pin connectors and how a power supply is supposed to fit in there. If you can't find a 400 watt power supply that fits then get a hold of Dell and see if they sell one for that computer.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect or boot up your hard drive
Test all leads that attach from the ((motherboard to your hard drive)) including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
dont forget to vote
hope this helps
