Question about Indesit Washing Machines
I am trying to take the belt wheel off the rearof the washing machine so i can replace the bearings anyidea how to undo the centre bolt
    President:
  • 1,462 Answers
Jam the pulley with a large screwdriver or similiar and use socket on centre bolt
Posted on Aug 22, 2008
How to install auburn gear limited slip in 67 Chevrolet 10 bolt differential ?
remove the axles, undo the back plates from the housing. remove the diff carrier bolts . take care to keep shims to the same side of the bearings. pull the diff centre out. remove crown wheel from the diff carrier . fir crown wheel to the new diff carrier (limited slip centre) . Refit carrier into diff housing. Best advice --have an accredited diff shop do the job for trouble free operation.
Jan 26, 2015 | Chevrolet Cars & Trucks
Am I the only one to ever own a Samsung J1055 front loading washing machine. Everyone tells me they do not have an adjustment for the belt, but mine definately has.. There appears to be only one b
I have the same machine and that is the only one unfortunately.
just try to adjust as it was and just change the belt. It will help you just a little bit!
let me know,
by Cris,The best on FixYa
Jul 06, 2014 | Samsung Washing Machines
How do you change the carbon brushes on a beko washing machine?
fist turn machine off then pull machine out becarefull there is still two pipes you can turn the water off to the macine then undo it and undo the wast pipe under your sink some times once you have pulled the machine out you can see the back plate undo the screws and take it off then you are looking at the back of the machine you will see the silver wheel and belt at the bottom where the belt is is the motor take the belt off the sound be star or bolts holding the motor on undo them there might me two or for bolts or screws ok once there out you can pull motor off onece motor is off you will see two black plastic caps thats the bruchers holding on by two screws or little bolts dont for get two check what way the brush go's back in the way the carbo is when you take it out is the same way you put the new one in ok hope i have helped
Nov 01, 2012 | Beko Washing Machines
I am replacing the bearings, but I cant get the securing bolt undone. HELP!!!
some machines had a left hamd thread on the drum shaft. you would need to turn this clockwise to undo it. look carefully at teh thread you can see to find out which way it goes.
once you can see which way to turn it to undo, you may have to tap the spanner sharply with a hammer to free the nut. you will probably find that the belt pulley is threaded and will have to be unscrewed as well
Mar 01, 2011 | Electrolux AWF 1435 Front Load Washer
Washing machine drive belt keeps coming off indesit wib111. the nut which holds the drum and the whell keeps also undoing, no matter how tight i do it up.
Try putting some locktite on the thread of the bolt. Loctite is a liquid you can buy to lock bolts into there threads.Alternativley the pulley that the belt runs on may be worn & sloppy in the centre where it goes on the metal shaft.you may need a new pulley as well as Loctite..but try the Loctite first.
May 31, 2010 | Washing Machines
How do you get the wheel bearing off a 1996 saab 900
assuming its a front one disconnect lower arm by undoing ball joint bolt remove brake caliper and disc disconnect hub from strut undo driveshaft nut and remove driveshaft u then split hub by pushing centre iut with a press,once split push bearing out with press then push new bearing in and refit everything the same way u removed it
Apr 14, 2010 | 1996 Saab 900
How do you change the front wheel bearings on a 1994 Kia Sephia?
its a pressed in bearing,i would recommend u to have it done by mec.but here goes,take wheel off,undo cv axle center bolt,undo brakes,calyper,disc rotor,undo tie rod,lower control arm ball joint,undo strut from steer.knuckle,slide knuckle off cv shaft.at this point u can take steer.knuckle to machine shop to seperate and install hub and new bearing or u can have fun taping out hub and bearing and theres a good chance that bearing will seperate when taping out hub,youll need a puller to take bear.part off hub,then taping them back in without damaging bearing.u will need ball joint seperator,socket for cv bolt,2 jaw puller.
Oct 03, 2009 | 1994 Kia Sephia
Need help fitting a clutch on a VW GTI Golf
undo centre wheel hub nut 30mm/32mm, socket. undo lower wish-bone outer bolts, disconect battery,/remove starter motor,/remove transmission mounting bolts to body frame ,/ remove all surrounding bolts around bell housing transmission,/ remove clutch cable from transmission,/ remove drive shafts from centre hub and transmission,/ make sure car is standing on axle stands at front of jacking points,/use a trolley jack to suport engine sump with a piece of wood,/ slide transmission away from flywheel,/lower transmision on floor,/undo all clutch plate preasure bolts 10mm,/remove thrust bearing located on centre transmision shaft ,.also make sure if fitted speedo cable needs to be removed.new clutch plate should indicate flywheel ,without fitting clutch plate wrong way round/otherwise transmision will not bolt to engine block.,
May 17, 2009 | 1999 Volkswagen GTI
Replace belt
Remove lid UN PLUG MACHINE FROM WALL SOCKET Undo motor bollts so it can be moved towards drum, GET OLD BELT AND LOWER IN YOUR HAND TOWARDS DRUM THEM MOVE BACKWARDS TILL CLEAR OF DRUM PULLEY ,get new belt and lower so it goes over rear of drum pulley (big wheel)make sure nothing is in drum,put one bolt of motor in loosely and roll belt over motor pulley wheel slowly forcing towards you if working from front a bit until ribs on belt are in grooves on both pulley wheels,Tighten up all motor bolts job done test it
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Ariston al1256t bearing replacement
Hi
I just did this on a different model - it is a normal (right-hand) thread
This is best done with the machine lying in its front.
1 - If it's a Torx screw (probably a T40), buy a torx bit for a rachet spanner - Halfrauds do them for about a fiver - you may need an adapter as well if your rachet is 1/2 in drive. This is far better than using a bit in a screwdriver handle.
2 - Heat the pulley around the screw (careful use of blowlamp) as it's fitted with thead lock compund and this helps to soften it.
3 - If that doesn't do it, try a cold chisel and hammmer to knock it around - you need to break the thread lock initially. You might need to replace the bolt after this :-) and you need to be careful not to break the alloy pulley.
4 - If after removing the screw the pulleyt doesn't come off, try heat again and wiggle it off rather than a straight pull.
Bear in mind that after removing the pulley spider, getting the old bearings out and the one ones in is also best done with gentle heating and is not a trivial job.
Use blue thread lock compound when reassembling as this will come off easier next time.
Whole job, start to end took me took 3 1/2 hours
Ricko
Mar 16, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
56 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
