Question about Compaq Presario 700 470024-192 Notebook
HEAD PHONE AND LAPTOP SPKEAKERS BOTH ARE WORKING SAME TIME
Hi sir
sir i had switched from vista to win xp after that my headphones and laptop speakers both works at the same time.i want to listen only thru the headphones.plz give a solution
i tried on the sound properties n swiitched the voice to headphones but that too din worked out.:(
    Guru:
  • 859 Answers
On the bottom of your laptop there is a sticker from the maker indicating your model version, as there are about five different versions of the Presario 700 series. I need to know what that model version is to get you compatible sound drivers to install or install again. This should fix your problem, and if it doesn't you have a mechanical malfunction in the headphone jack, which when a plug is inserted should disable your speakers.
Regards,
Worldvet
Posted on Aug 23, 2008
  • Ashish Raheja Jul 12, 2011
    hi Sir, I am facing the same problem, my Laptop model is Compaq C738TU. Kindly provide me the right solution.
    I'll be very thankful to you for this.
    regards,
    Ashish
The headphone and external speakers don't work on my acer but the internal speakers are fine
check if you plugged them in the proper port the green one is proper for speaker.
Mar 31, 2011 | Acer Aspire One A150-1006 Notebook
I have installed vista home edition on my pc and my headphones seemed not to be working on either the front nor on the backside green jack,the microphone are working fi9 and the external speakers are also...
Go to control panel, click on sound and check if the head phone jack is enabled and also if the drop down list under head phone jack properties states 'use this device'
I had a similar problem with my build in speakers on my laptop also in Vista and the problem was simply that the speakers were not enabled.
Hope that solves the problem for you.
Jul 24, 2010 | RaidMax Samurai 908 Yellow Mid Tower ATX...
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Sir ihave c795tu laptap in this system only support vista but iam using windows xp.all fuctions are perfectly worked but headphones are connect the output of actual speakers are also coming
Double right click on the speaker icon in the taskbar tray. Then turn the speaker volume all the way down and adjust the headphone volume to the level you would like it. That way you will get sound coming rom the headphones only and not the speakers.
Nov 11, 2009 | Compaq Presario 700 470024-192 Notebook
Sound from laptop speakers/headphone at same time
Dear Sir,
V3000 is not compirtbale for Xp its only for Vista OS. There is no solutions for Xp. If you will exact driver for sound driver and UAA then it clould be solved.
Thanks
Cheers
Sep 19, 2009 | Compaq Presario R3000 Notebook
Voice in both headphone and laptop speaker so its worthless to us
hi!
You need to adjust a little bit lower in your master volume settings for the microphone. including the master volume.
You can find it at the buttom navigation bar If your're using windows XP. Try to adjust the settings. Your headphone had a mic therefore u need to test it until such time ur speakers will not echo.....
Please reply so that we can diagnose a better option.
Jonags3.
Jan 05, 2009 | Compaq Presario 700 470024-192 Notebook
C797VU not working properly on Win XP SP2
ihave compaq c797vu model
for audio headphone and speaker use conexant smart audio 221 driver,it solve your problem
i have problem of touchpad ,do u have proper touchpad driver and how to confiqure,please tell me
Oct 29, 2008 | Compaq Presario 700 470024-192 Notebook
Headphones and laptop speakers work at the same time
I have compaq presario c773tu laptop .I can not find sound driver on internet.
Jul 03, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
117 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
