Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dish washr it won't drain
  • smithrex Aug 23, 2008
    my kenmore diswasher will not drain. I have model # 363-14071793
  • 876 Answers
Can you access the drain hose without moving the dishwasher out? Is it close to the garbage disposal. You probably have a plugged drain. I would begin by plugging the sink that the garbage disposal is in and filling it full of hot water. Then I would unplug it and turn on the disposal and continue running water in it. This should clean the disposal drain well.
If you can access the dishwasher drain hose, you will need to disconnect it and look for a plug. If you can unplug the dishwasher do this first. It may be hardwired in, but some are not. It will all be behind the adjacent cabinetry. Have towels and a bucket handy. It is a good idea to always run some water through the disposal after running the dishwasher (they usually drain into that sink.)
If you cannot access the drain, I would clean the disposal and check all other household drains for slow drainage before calling a plumber. or your dishwasher repairman.
Good luck to you and thank you for using Fix Ya.
Posted on Aug 22, 2008
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
I have whirlpool du915pwpb0 and accessible broken pieces of dishes have been removed from filer module but now unit won't drain at end of cycle
If it drains during the other stages of the cycle it sounds like there is a faulty control that tells the unit to drain at the end of the cycle. If it is not draining during any of the stages of the wash cycle it may be a faulty pump.
Dec 10, 2012 | Plumbing
Water won't drain
Maybe the filter is blocked. It should be located near the bottom of the machine at the front and should unscrew. Have a dish and bowl handy to collect the water.
Oct 08, 2012 | Cars & Trucks
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
HOW DO I DRAIN WATER FROM MY SMEG DISHWASHER
There is a screen filter at the bottom of most dish washers, if the screen gets dirty it probly won't drain properly. Check the screen and clean if neccesary. If not that, then pump may be getting weak.
Jun 25, 2012 | Smeg Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Dishwasher won't drain. Dishes were clean after cycle. How do I manually drain without overflowing?
Hi coxcrewof8,
The easiest way is to lay the drain hose flat on the floor, preferably out a door towards the nearest drain.
Gravity will sort out the rest.
Good Luck
* If you found this solution helpful, please rate it
Jul 05, 2011 | Dishwashers
New washr leaking from drain hose what do I do
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Oct 10, 2010 | GE WBSR3140DW Top Load Washer
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
125 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
