Question about Sony PlayStation® 3 (60 GB) Console
No output My playstation 3 turns on sounds like it reads the cd but nothing comes on the screen and no audio and it doesn't charge the controllers.
  • 50 Answers
So it must be a problem in the circulation of the power in the ps3 ....so i think dat ur power supply of ur ps3 must be damaged or there's something in the power cable so try to contact sony for more useful information ....but there isn't any other solution .....u may buy a new power cable or u can change the power supply
Posted on Aug 23, 2008
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
My playstation turns on but nothing happens after that. There is no display or sound output. It will not turn off, gibving two beeps if you try to shut it down. The hard drive light comes on for about...
hello try resetting it turn the ps3 on then press and hold the standby button you should hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset it self
regards
shaun
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
When I turn my ps3 on, there is no audio/video. I don't think it's a software update problem, as I was playing my ps3 about two/three hours ago. I turn it off at the back, chill for a couple seconds, then...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
Play station fell on the floor and the top is cracked. The screen turns blue when it comes on but will not read any discs nor open door.
well it sounds like the sensor for reading disc is broke it will not read anymore disc the disc tray is also stuck will not open without repairs and the screen is turning blue because the video output inside the console(this transfers the picture onto the screen is busted if u have a warranty use it contact playstation by going to playstation.com hope this helps you.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
When i switch my playstation on, nothing comes up on the screen, and the controller wont turn on
Turn the PS3 on from the console by pressing the power button and holding it until you hear the first beep followed by a second beep. let it go after that. This resets the video to seek an active output on the console itself. Also try plugging your controller into the ps3 with the provided usb cable. this should reactivate it with t
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
My PS3 turns on to green light but nothing comes on screen
After the system boots up, hold your finger down on the metal spot where you normally turn it on. it'll completely reset all settings & hopefully set to the proper video output.
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3 HDMI & AV outputs not working?!?!?!?
change the sound output to HDMI? does the sound work on just like a normal tv channel?
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
Ps3
keep you finger over the power button for 10 seconds while it is on. This will reset the video output settings and you will be asked to choose a new video output
Jul 03, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 wont read some cds or play downloaded demos.
I'm also having this problem as well, it has to do with the OS and it is corrupted. It seems like the "Game mode" has been corrupted preventing us from playing games on the hard drive or reading games.
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
