Leaking water from head unit into room
I have a massive amount of water pouring into the room from the unit in the wall. How can this be fixed. My model number is ASU9C1, fujitsu. I was researching and a possibility is a clogged drain line but I don't know how to access this or how I can fix this myself (which I would prefer). Please provide me with as much specifics as possible on the clogged drain line solution to other solutions to this Mark Paratore
  • Anonymous Mar 30, 2009
    I have the same problem with mine - same model number.
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
  • 86 Answers
SOURCE: through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Posted on Mar 17, 2008
motor1258
  • 6674 Answers
SOURCE: ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Posted on Aug 14, 2008
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Posted on Jan 23, 2009
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
Aug 01, 2014 | Haier HWR08XC7 Air Conditioner
Aqualisa aquastream - when I turn it on the water pours down the wall. When turned off no trickle or leaks.
Surely something is leaking. I am attaching a diagram of the parts inside the unit for your reference. See if you can access the parts to find out which one is leaking and replace the broken part.
Feb 16, 2014 | Home
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
Water leaking into room
Angle your unit so the back is lower than the front and the water will run out the drain hole on the bottom.
Sep 02, 2009 | GE Heating & Cooling
Leaks water into room
Try tilting the a/c to the back. In most cases the manfacture will seguest that the unit be tilted to the back slightely (no more that 20 degrees). That is what I would try. If that dont fix it let me know and we will try together and solve this problem. Good luck
Aug 24, 2009 | GE Heating & Cooling
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Refrigerator leaking water out
being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
Apr 02, 2007 | Kenmore 74522 Top Freezer Refrigerator
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
