SOURCE: how to install XP in toshiba Satellite L45-S7423 laptop
Dear ,
i think there is SATA hard drive in your notebook, well if you wanna to install XP on this notebook , first you have to enable sata support in Bios then you can put the XP bootable Cd in this notebook and install XP . but remember you also have the XP drivers for your Sound , Display and Modem.
Cheerup and Be Happy Always
I am only going to say this once........vista is the best ........ believe me alot of people are afraid of vista ... I cannot understand why may I ask you SIR why are you changing from Vista to XP when they are both the same OS .......it is senceless ........exeriment man oh man experiment you will succomb.................
SOURCE: I need to locate the cmos battery on my Toshiba
This information is in the Users' Manual, which probably came on a disc shopped with the computer. If you can't locate the disc, go to Toshiba's Web site and download the manual from the support forum.
SOURCE: Cannot Reformat Toshiba Satellite P200 using the Recovery P200
1. after recovery is done, you dont find sound on your machine
2. no problem, download the Pcwizard 2008 from the given link
save it & install it in your computer, it will give you your all
devices name and model number...
3.http://pc-wizard-2008.en.softonic.com/download#pathbar
4. note down your device name and model number and download
the drivers from the given link.
5. http://www.lostmydrivers.com/soundcard-drivers/realtek/
Note:-
If you want to Re-install your OS you can re-install and follow the above steps, hope you will solve your problems.
all the best.. try it..
Warning - You may loose all of your saved files - Back-UP first!!
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you may loose all of your files and after market downloads.
Back-UP first!
error code 06-0238-0000 did not allow me to install the Toshiba Recovery Disk but does allow an install of Windows *** if I use a different install disk. Go Figure ?
