Welding Tools Logo
Posted on Jun 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an older Hobart beta mig II welder and the drive motor does not work when trigger is pulled. any ideas
David Soto
Level 2:
  • Expert 414 Answers
  • Posted on Jun 26, 2011
David Soto
Expert
Level 2:
Answers
414
Questions
Helped
193547
Points
758
Hi:
have you tried to by-pass the gun switch by disconnecting the gun cable (not the lead) and using a paper clip to by-pass the gun?. If the motor turns then you need to replace the gun switch if not probably the PC board fuse it's blown.
Hobart beta 200 arks without pulling trigger have to pull trigger to feed wire
I was a service tech/manager for 10 years and had my repair business for another 8 years after I left the company I worked for. Can't really remember that exact machine's theory of operation, but check your weld output contactor. Sounds like it might possibly be stuck In the closed position.
Drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
Hello, I have a Hobart 180 and the wire feeder motor won't run. I replaced the wire feed motor and it still won't run. any ideas?
Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
My welder is tripping the breaker when the trigger is pulled. This does not occure every time, but quite often.
I am having the same exact problem on an old Hobart Beta Mig 200
sometimes i can weld for 5 minutes and other times as soon as I hit the trigger it trips the 50amp breaker. Any help?
2helpful
1helpful
I have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
My hobart 135 will not feed wire. I checked for voltage at the drive motor no voltage. The gas still comes on when trigger is pulled but seems that the problem is in the control board?
does it have a reset button? if so it has gone bad, if not there is a fuse or something inside. they protect that circuit against shorting at the working end of the gun. happens ALL the time.
Hawk
I need a liner for a Hobart Beta Mig II so I can weld aluminum. Any ideas on where to find one online?
You can buy liners for torches from most welding suppliers, if the torch is very old, it may be time to update.
Top Hobart Welding Tools Experts
Sean Wright
Sean Wright
oneStan
oneStan
Kardoc
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
