Question about Nokia 6126 Cellular Phone
Nokia 6126 Phone will not open
I tried to open my phone that has been stored and when I push the open button on the right side of the phone, it won't open. I tried to manually open it but it catches and I don't want to force it open. Help!
  • Nokia Master
  • 1,800 Answers
Its alright to open it manualy
and dont be fraid of forcing it
Posted on Aug 25, 2008
SOURCE:
How do I open the disc tray on Aspire E1-510-2495?
Pgs 12 & 13 of user manual. Right side of computer on drive cover, push the oval button. If the drive does not open, straighten a paperclip, and insert it into the small hole to the right of the eject button and push.
Feb 27, 2015 | Acer Aspire Computers & Internet
Cd wont open
Take a large paper clip and open it.....there is a small hole below the tray usually on the right side. Push the end of the clip to manually open the drive.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
My flash won't pop up.
Theres a button on the side of the camera with a lighting bolt on it push to open leave lens cap on to test then go to menu look for flash/ bracketing and set to open
Dec 19, 2012 | Nikon D60 Digital Camera
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Up,right and clear button not working when opened
i have the same problem on my phone and i was unable to fix it but i could get the clear, up, and left buttons to work by sliding the screen down a tiny bit until the buttons on the screen light up (they are not lit up when the phone is slid out). you won't be able to push the top row of keys, but by sliding the phone slightly down you should be able to use the clear, up, and left keys
Jul 23, 2010 | Samsung Sway SCH-U650 Cell Phone
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
How to remove the cartridge from hp photo smart 7960
Hello the manual way to release cartridge is
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Look for the gray-colored carriage on the right side of the printer.
  4. Find the horizontal (bottom) edge of the carriage and follow it towards the back (or in) until it makes a 90-degree turn. Follow it down to the ¼ inch-high, black-colored capping station.
  5. Using a screwdriver or similar tool, push the capping station toward the back of the printer.
    NOTE: Do not pull on the ribbon cable when moving the carriage.
  6. Making sure to not push up on the carriage, move the carriage to the middle of the printer. If the carriage is still locked in place, push the capping station farther into the printer and try moving the carriage again.
  7. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges and store them according to specifications.
  8. Close the top cover.
Sep 03, 2009 | HP PhotoSmart 7960 InkJet Printer
The flash is not openning
The flash may be set on "Suppressed" - meaning there will be no flash. On the back, by your right thumb, there is a round button. It's the ring around the MENU button. On the right of this you'll see a symbol which looks like a lightning bolt - (Flash). Turn on the power. Push down on the right side of this ring type button, towards the lightning bolt. Everytime you push, it sets the flash for a different mode. Try changing the flash mode and see if it doesn't fix your issue.
Jul 12, 2009 | Photography
My psp wont charg
If it won't charge and wont power up then same thing happened to me. If you are willing to open up your psp there is a video on youtube that can show you whats wrong. The cable that connects the buttons on the right side most likely disconnected from the main board and the right side of the psp including the buttons, the power switch and the top right trigger won't respond. When you try to turn on the psp and when its charging if the light won't come on then you might have this problem.
May 10, 2008 | Sony PlayStation Portable (PSP) Console
Replacing battery
click the button and try to slide down
Jan 21, 2008 | Nokia N70 Cellular Phone
Nokia 6126 Cellular Phone Logo
220 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
