Question about NorStar T7316E Corded Phone
Forwarding calls to cell phone
Hello Expert,
We currently have T7316E 16 & 8 button telephones. we have phone system on inverter power & then the inverter konked out so the phone system shut down on us and we lost some of our programming. we had it programmed to forward calls to cell phone which is needed in our industry. the way it worked before was to select "Feature, 4, then 7, then 9 & the cell number" but now when i try it i get a message saying invalid number. is there a setting somewhere i am missing. here is how i got settings set.
Fwd no answer…
Fwd on busy…
DND on busy : N
Hands free :None
HF answerback :Y
Pickup grp :None
Page zone :1
Paging :Y
D-Dial : Set1
Priority call :N
Hotline :None
Aux. ringer :N
Allow redirect : Y
Redirect ring : Y
ATA Settings
SM supervisor :N
--End of List –
Your assistance to this matter is greatly appreciated. thank you for your time and quick response.
Regards,
Sid Bauman,
Bauman Sawmill Inc.
4201 Powell Road
RR#1
Wallenstein, Ontario N0B 2S0
Ph # 519-698-2741 ext. 221
Fax # 519-698-2831
E-Mail : sid@baumansawmill.com
  • TLeath Sep 12, 2008
    We have our office phones set up the same way and are also unable to use the call forwarding option.
Hi, not sure if this helps, but in our office you just have to press feature - 4 (to activate forwarding), 9 (for external line) then the number.
Worth a try at least?
Posted on Oct 01, 2008
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
T7316 phone does not cancel call forwarding
#73 is a a feature you use on a telephone line to cancel call forwarding (cfw) of an outside call (some codes may differ). You need to have the dial tone of that outside line to cancel the cfw. to cancel the cfw of a norstar set (internal calls to extension) just press the cfw key or press 'feature #4'
Apr 15, 2014 | NorStar T7316E Corded Phone
Call foward
Actually it's your telephone company forwarding the calls. With many phone companies, you dial *73 on your home phone to cancel the call forwarding. If that doesn't do it, contact your telephone company for their instructions regarding call forwarding.
Nov 22, 2013 | Uniden DECT 6.0 Cordless Telephone...
Disable call-forwarding on avtech 5.8
Since call forwarding is a service of your telephone company, you'll have to go through their procedure to cancel forwarding. Try dialing *73. If that doesn't do it, then contact your telephone company for their procedure.
Jul 01, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
For a GE ProSeries telephone Model 2-9980A S/No 00098864 corded business phone - 1 line with speaker phone. What are the directions to forward the phone to another number? And, also, how to cancel the...
Go to settings on your phone, click on the phone option, it will display different option, select call forwarding or call divert, enter the number you forwarding the call to and press ok, you are done. follow the same procedure, when you get to call forwarding, you can select to cancel as you can no longer add a number.
Take care.
Oct 14, 2010 | Cell Phones
Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Dec 07, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Hi - have a Norstar T7316E phone and cannot figure out how to turn the ring off when I'm on it.
If your telephone rings when you are on a call you will have to go into programming on the system and set DND on Busy to "Y" it will be set to "N" at the moment hence your phone rings when you are on a call, be carefull if your phone is the only phone to ring on incomming calls if you get a second call comming into system when you are on a call there will be no audiable ringing on any telephone to aleart you to this second i/c call.
Oct 01, 2009 | NorStar T7316E Telephone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone Logo
414 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
