Question about Panasonic KX-TG2740 Cordless Phone
Deleting messages from handset
How do you delete messages from the handset and not the base? Thanks
danielle
  • elsul Sep 14, 2008
    when you call in for messages, how can you delete them?
Not usually. I recently purchased a new (refurbished) base station and cannot get it to talk to the handsets
Posted on Sep 08, 2008
How do I listen to and erase message?
Are you trying to get the messages from the phone directly or by calling into your phone.
If the answering system is on, then you can play back the messages from the base by pressing the Play/Stop button.To delete a message from the base, press the Delete button (has a 0 with a slash through it) while the message is playing. To delete all messages, press the Delete button when the phone is in standby. From the handset press the Messages softkey (has an envelope icon) when the phone is in standby. Then press Play/2 to play back the messages. To delete a message, press Delete/4 while it is playing. (Deleting all messages can only be done at the base.)
If you are calling into your phone system, you need to have set a two-digit PIN from either the base or the handset and remember it. Then call the number for your phone from a touch tone phone, press 0 and then the PIN within 2 seconds. (Do this while your greeting is playing or after a series of beeps when the phone answers your call after 10 rings if the answering system was off.) If the system is off, start by pressing 0 6 to turn it on. Press 0 2 to play back the messages. (All commands need to be entered within 15 seconds of the last command finishing with both keys pressed within 2 seconds.) To delete a message, press 0 4.
Uniden has the manuals for most of their phones on their support site: http://www.uniden.com/scat/cordlessphones_mnl . Phones are listed in numerical and alphabetical order; thus the TRU9480 manual is on page 7. The direct link to the TRU9480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9480om.pdf .
I hope this helps.
Sep 01, 2011 | Uniden TRU9480 Cordless Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
I have a Uniden DECT 6.0. How do I delete the
This probably applies to your model:-
From the expansion handpiece - while the message is playing - hit the 4 button - or 4:delete button.
From the base unit - while the message is playing - hit "delete".
You can only delete all messages at once from the base unit.
Mar 29, 2010 | Uniden DECT 6.0 Cordless Telephone...
We have a single Philips CD 445 Phone Our problem is how do we delete messages from the machine, we have lost the paper work with the instructions. alanbarlow1940@hotmail.com
Deleting an incoming message
From the base
Press (erase)f during message playback.
• The current message is deleted.
From the handset
During message playback, press OK
to enter the options menu.
Select DELETE. Press OK.
Deleting all old incoming messages
From the base
Press and hold (erase) during standby.
• All old messages are permanently deleted.
From the handset
Press (menu)
Select ANSWER MACHINE >
DELETE ALL. Press OK.
• The handset displays a confirmation
request.
Press OK to confirm.
deleted.
Note
Unread message(s) cannot be deleted,
and deleted message(s) cannot be
recovered.
Feb 13, 2010 | Philips Lands Phones
How to remove Uniden handset from base
The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
Mar 08, 2009 | Uniden TCX905 Cordless Expansion Handset
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Jul 16, 2008 | Uniden TRU8885-2 Cordless Phone
Philips SE 435 Handset beeping intermittently
I had this problem, solved it by going to the advanced settings menu and resetting the handset. I guess the handset got out of sync with the base station after I deleted messages... once reset it was fine.
Jan 27, 2008 | Lands Phones
Event LED on my new Philips CD535 Duo Phone
go into call lists (centre button up then call lists) and delete the calls in there this will solve the problem
Aug 24, 2007 | Philips DECT 2252S Cordless Phone
Panasonic KX-TG2740 Cordless Phone Logo
96 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
