Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco Italia Sup021 YR flashing red malfunction light
I have taken my Saeco Italia Sup021 apart to inspect the grinder but after reassembly I'm getting a red flashing malfunction warning indicating the grinder motor is blocked, or dispensing unit motor is shutdown. Does anyone know if there are grinder alignment photo details available and or diagrams? Or is there a button combination sequence that will reset the coffee machine?
  • danielbench Apr 29, 2009
    grinder red light is on .how do i fix that
  • glynissmith May 11, 2009
    Will not switch on. I had just used it and whilst cleaning it the descale light came on, then everything went off and it will not start up again.
  • 3 Answers
Posted on Nov 29, 2008
Thanks, Mirran.
I'll check this out and report back.
Cheers,
John
Posted on Aug 24, 2008
  • 515 Answers
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
Hope this will help you.
/Mirran
Posted on Aug 23, 2008
  • 1,089 Answers
HI
If you don't hear the grinder motor, I would say you have a disconnected grinder wire. These motors are DC so make sure that you connect it correctly or your grinder will run backwards.
Posted on May 30, 2009
I got a saeco italia and the coffee tastes too light. how can i adjust it to make the coffee strong??
Hi
There are 2 knobs in the bean hopper. Turn the big knob to 8 and the small knob to the plus (+), then back one mark. If the grinder is already lower than 8 and the grinds look larger than coarse sugar you might have a seperated grinder.
Dec 21, 2010 | Starbucks Saeco Italia Digital Barista...
Hello- I have a Saeco Italia machine, about 4
Try this press the pre ground button then the coffee brew button, if water flows from the spout then the grinder chute is blocked, if no water flows then the brew unit is screen blocked.
If grinder, then remove the brew unit and check the chute from the grinder.
Sep 27, 2009 | Coffee Makers & Espresso Machines
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Machine won't return to the home position
Hi
2 things.
1. You may have a broken brew drive.
2. You may have a brew drive that has jumped its micro switch.
Call a service center
Apr 23, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR how to clean metal filter?
The item you were refering to is: http://cerinicoffee.com/Saeco_Brew_Group_key.asp
It is used for removing the screen on brew groups: http://cerinicoffee.com/saeco_vienna_brew_Group.asp
It connects to item #4 below.brew_group_vienna5.jpg Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 28, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
1,202 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
