Question about Whirlpool Duet GHW9150P Front Load Washer
Walking Washer Is there a solution for the vibration and walking of Whirlpool Duet purchased 3 years ago?
  • 876 Answers
Front loading washers do not do well on the new "soft" flooring that is installed in so many homes. We placed a thick commercial style rug with thick rubber backing all the way under ours which was sitting on Pergo and it stopped the problem. This wasn't my idea, it was what the repairman told me AFTER a service call! You should be able to purchase such a rug at a hardware store or a large department store in a small size. The rug just needs to really stick to the floor.
Good luck to you and Thank you for using Fix Ya!
Posted on Aug 22, 2008
SOURCE:
How to get to the shocks on a whirlpool duet washer
1) live wires touchign the chassis
2) ground defective from the pole bar in ground
3) some wires is not having the cover and touching the chassis
4)call some electrician for isolated the shocks, is dangerous
5) Discharge EM,when you get some electrical charge walking in mat
God bless you
Jun 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool Duet 9750 takes a long time to spin out and has a difficult time trying to balance
I owned a Whirlpool Duet and had spin/balance problems when I washed heavy and light items together. During a deep freeze my drain hose froze. Did everything I could think of until I ran hot water through washer. It took awhile to thaw. If your floor is weak, you will have a lot of vibration and walking. Hope this helps.
Dec 28, 2011 | Whirlpool LSW9750 Front Load Washer
We purchased a Kenmore washer about three years ago and it hasn't operated correctly since the purchase. During the agitation process it vibrates intensly. It appears to me that whatever was intended to...
I didn't see a Sears Parts site for a prefix 111 but here is the one for a washer (Whirlpool / Kenmore) with the prefix 110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.27642600
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is an illustrated description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Also check that the "Shipping Pins" have broken loose. These pins are designed to be broken during installation and they should fall into clear plastic catch tubes.
Nov 30, 2009 | Kenmore Washing Machines
Walking Washer on pedestral
Not me!......My problem was a working washer machine on pedestral.
May 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
It is walking even after several attempts of leveling and balancing.
you've got something out of balance or round,i don't think its a good idea to attach to floor
May 09, 2009 | Whirlpool LSR7333 Top Load Washer
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrating Whirlpool ghw9100lw2
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Feb 07, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
161 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
